ok another cam question..........
would the comp cam XR276HR be a bad choice for a 383 with a ported tpi intake?
adv. duration is 276-282
@.050 224-230
.502 .510 lift
L.S. 110*
Yes, what is your goal for the car? Then we can help you.
well I wanted to keep the car streetable and pick up some extra hp and torque but its not going so well.
I have the motor together and running but it just isnt making much power at all.I also have a top end problem that seems to be impossible to figure out. it seems to run good until 4500-5000 rpms then it falls on its face. now I have been able to run it to 6000 a few times so the problem seems intermittent.
I have replaced all the ignition and the fuel system checks out great also.I also ran it with a scanner hooked up and everything seems good to go.
I have had a chip burnt for it, then I dynoed it and got some a/f readings and it runs pig rich after 3600 rpms.it just steadly fell on the dyno graph below 10.1.........so I sent the graph to the tuner for refrence and got a new chip but the problem still persists.I havent stuck it on the dyno again because I think it would be a waste of money.
I dont know where the problem could be because I have went over everything two or three times.and I know the cam was degreed in right also.
does any-one have any other ideas?this car is driving me close to selling it or something soon.
oh ya its a 91 also.
You wont get the full power that cam can give with a ported TPI on it, so no i wouldnt use it. Something more like the Accel 211 or Tpis ZZ9 if you keep TPI.
Don't sell the car. It sounds as though you have 2 issues. 1 if you ever want to make power past 4800rpm you have to ditch the TPI intake. There is no way around it. The Super Ram, Steathram, and LT1 intakes will get you to 6K. Your second issue is your rich condition find that and you will have a great car to drive evertday. BTW list your mods please.
balanced eagle rotating ***. with srp pistons all forged. 10.1 compression
Long tubes
113 heads ported with 2.02-1.60 valves
986-16 comp springs and 10* retainers and locks and cam
bbk throttle body,and ported plenum and base.
2500 rpm stall
high vol. oil pump
1.6 R/R but not on the car.I went back with stock for now.
even though the intake is still stock it should pull above 5 grand right?I thought it would just stop making power at about 4500 or so?also I believe the rich issue is taken care of now.and the lt1 intake would have to be modded to replace my tpi wouldnt it?
the 110 LSA might give you a problem. Most TPI/FI systems seem to like 112 LSA's. The former should cause a rougher idle and maybe smog compliance prob's.
well I think I got it.
I took the car out again with the fuel gauge hooked up and at wot it lost fuel pressure.I read a post before I left about c4s cutting out below 1/4 tank of gas.well it just so happens I havent had the car above half since the new motor, so I stoped and got gas and ran it at wot again.well I got no fuel pressure drop and the car shifted out at 6000 rpms like it should.
I have spent about 5-600.00 on this problem and it was as simple as a bit of fuel in the tank..
so now I guess its back to the dyno for some real pulls and some more a/f readings so I can get this thing tuned properly.
the thing that gets me is it never did this with the old l98 in it.I guess more g's slosh it to the back at wot..
I have a walbro fuel pump and when the tank gets below 1/2 full I already plan on going to the gas station. All it takes is one highway jog to 100+ to virtually knok off a few ticks on the gas guage.
Big hp cars suck gas at wot and with the g's and the virtual squat the car does when you drop the hammer you want to keep your tank full.
is there a pickup tube in these tanks?why would the pump not beable to pick the fuel up under wot?.I have a 95 z with the lt1 and I have had a few diffrent sport cars that where pretty stout and never have I had this problem.
I personally have never expierienced any problems with running low on fuel, even down to 3 gallons in the tank. Only thing is the fuel is used to cool the pump so I like to keep her at least 1/3 full at all times.
The pulsator is just above the fuel pump. The gas flows from the pump thru the pulsator and out of the tank.
I dont know what it can be but alot of guys seem to be having the same problem with there c4s..I guess I can take everything apart and start cleaning things up and see what happens.there has got to be a reason these cars do this.
Pull it out with the fuel lines connected, then turn the key to pressurize it to find a leak. Change the sock on the end of the pump while you have it out.
I am going to pull it tomarrow.I have never had the plesure of pulling a pump on a vette so a few pointers would be greatly appreciated.
thanks.
well your in luck becase the c4 fuel pump is the easiest i have ever had the pleasure of changing. pull the fuel door off. then approx 10 bolts around the fuel pump assembly, and out it comes. probably take about 10 minutes to get it out.
