help is ecm bad?
Old Apr 30, 2005 | 10:00 AM
85autoxr's Avatar
85autoxr
Default help is ecm bad?
`i have 383 super ram afr 195 heads, custom chip and jet hot chip just swapping chips i can scan engine and 1 has egr code other does not. also both halve a lag off idle new o2 sensor tpi at .52 vdc..anything else i need to tell you? or is it worth just getting a new ecm?
Old Apr 30, 2005 | 11:15 AM
Morley's Avatar
Morley
I'd bet that the "custom" chip has EGR turned off and the other doesn't.
what makes you think you have a bad ECM?
