Hatch opened by itself while driving !
Old Apr 30, 2005 | 04:10 PM
rayosequis's Avatar
rayosequis
Default Hatch opened by itself while driving !
I had some previous problems with my PKE acting up with the doors locking randomly and making strange noises, I turned the PKE off, and the problem stopped. Yesterday, I was driving about 35 and the doors locke, and then the hatch opened BY ITSELF. It scared me to say the least. Any ideas as to what this may be from ? Anything to do besides yanking the whole PKE module out of the car ? I pulled the PKE fuse out, but am unsure of where to proceed from here as the PKE light came on, and it started to lock and unlock the doors while the car was running.
Thanks in advance,
Ernest
Old Apr 30, 2005 | 04:18 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Would you like me to contact my priest and see about an exorcism?
Old Apr 30, 2005 | 04:32 PM
rayosequis's Avatar
rayosequis
Yes, maybe all of the forum members can join me in a chant! BE GONE C4 DEMONS !!
Old Apr 30, 2005 | 06:54 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
Be gone you evil C4 demons! In the name of GM I cammand you!
Old Apr 30, 2005 | 07:18 PM
cv67's Avatar
cv67
St. Jude Donor '05
Old Apr 30, 2005 | 07:48 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
The Power Of Duntov Compels You!!!
:d
Old Apr 30, 2005 | 10:13 PM
JackDidley's Avatar
JackDidley
My 86 would open the hatch at random times. Maybe every 3 months. It didnt care if I was doing 70 on the parkway. I took a shoelace and made a safety catch. Tied it to the latch and made a loop go around the part on the glass. That way it could only pop up 2 inches or so.
Old Apr 30, 2005 | 11:46 PM
Hotred94's Avatar
Hotred94
I've had the same problem zipping down the freeway. I think it could be spurious radio signals because it happened in a construction zone (crews use radio equipment). Turning off the car usually will reset everything.
Old May 2, 2005 | 11:21 AM
rayosequis's Avatar
rayosequis
Very strange, I had a friend suggest that I disconnect the power from the latch that opens the hatch, so I may end up going that route. I didn't think the car should be able to respond to the transmitter or any signal while you are driving. So I guess I am going to pull the PKE module out, and see what happens. Does anyone know where the other fuse for the PKE is right off hand ? I remember there being one in the dash fuse panel and one somewheres else.
Thanks for all of your help and chants !!
To Hatch opened by itself while driving !
