T56 into an auto
For any hope of this working you would need a T56 out of a 97 and older F body. I think the LS1 started in 98 for those cars.
The only external traditional gm engine that I know of was the 454 and the 400 and that was to increase the counter weight for the large stroke.
Yes, the t56 works you have to adapt the C-beam and shorten the driveshaft. Small things like have a hydraulic line made for mating the slave and master cylinder and very little needs to be done to clearance where the shifter goes through the floor.
The latest GM small-block, the LS1, and its predecessor, the LT1, are using a mix of both ideas. The front of the crankshaft is neutral, but weights are still added to the flywheel or flexplate to provide final balancing. When choosing a crankshaft to build upon, don't make any final decisions or purchases until you're sure about the rest of your reciprocating assembly. If you spend the extra cash for a lightweight crankshaft, then realize that your heavy H-beam rods and thick-deck nitrous pistons will force you to drop an additional $300 to your machinist to balance the assembly, you're not getting it right. Machinists add heavy Mallory metal to the counterweights of a crank to achieve the correct balance. This is what we're trying to avoid, and if you plan to run lightweight goodies ahead of time, you can reap the benefits and save the additional machining costs. A little research is all that's required.
All stroker cranks and serious aftermarket units are internally balanced. The manufacturers have done their homework and can recommend a good rod-and-piston combination that will keep you out of the Mallory metal and be strong enough for your chosen application. You want to get the lightest crankshaft that can support your target horsepower range, and that shouldn't be hard for a street-bound car. For instance, the SCAT "Superlight" crank we eluded to earlier has a 1,700-gram bob weight, and can be teamed with their 4340 forged I-beam rods (that weigh 600-grams each) and SRP Ultralight pistons to easily support 600 hp. This flyweight combination would rev quite freely, and a very lightweight balancer (like those offered by ATI or BHJ) is all that would be required to control harmonics. This is only one example, but if you're looking to step up to a more serious combination, we'd recommend touching base with a crank manufacturer and getting their recommendation based on your overall package and performance goals.
is from:
http://www.popularhotrodding.com/eng.../0305EM_crank/
and, here is an interesting thread (make sure you read to the end):
http://web.camaross.com/forums/showt...0&page=1&pp=15
Tom Piper
