Removing hood!
Old May 1, 2005 | 02:05 PM
Movnviolation's Avatar
Movnviolation
Default Removing hood!
I am putting a new motor in my 89 and will be pulling the old one out this week. While surveying what I need to do, it looks like it would be safer to remove the hood to prevent any damage, and much easier access. I am doing this by myself. I will be pulling the six spd. with the motor so I want all the room I can get.
What kind of monster am I creating with alignment putting the hood back on. It looks like four (4) bolts hold the hinge on each side. Are the two bolts going into the frame going into stationary nuts? I can not see a way to get under there to locate the nuts! I will leave the shims in place with tape, and try to scribe the bolt positions on the hinge bracket in an attempt to get it back in the same alignment.
Any tips are most welcome! Thanks in advance!!
Old May 1, 2005 | 02:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I'm sure alignment will be "fun" when it goes back in but I've heard that the hood is very heavy and difficult to handle without proper equipment and/or personnel.
Old May 1, 2005 | 02:36 PM
1985 Corvette's Avatar
1985 Corvette
Well, unbolting the hood easy by yourself, but removing the hood is really a two person job as well as installing it so as to prevent any damage to the hood. Definently document how many shims are on each side.
Old May 1, 2005 | 03:07 PM
Fubar569's Avatar
Fubar569
i plan on dropping my 700R4 out the bottom then yanking the motor out the top with the hood still on...if you're careful enough you won't harm the car at all...
Old May 1, 2005 | 03:29 PM
89corvetteken's Avatar
89corvetteken
Default hood
I to just pulled out my motor and trany from my 89 and I did remove the hood.
It is a 2 person job.Even with 2 people I still nicked the paint on the front edge of the hood and cowling.It is much heavier than it looks.
Even after scribing the brackets it still did not line up so prepare to basically work from scratch.
When I have to remove it again I will jamb carpet foam between the front of the hood and cowling to protect the paint.
Old May 1, 2005 | 04:00 PM
Movnviolation
I never planned on removing the hood by myself. It looks heavy!
89corvetteken, are the frame holes threaded for the bracket bolts? Are there only four (4) bolts holding the hood on? Thanks!
Old May 1, 2005 | 04:12 PM
ar91c4's Avatar
ar91c4
just pull it out the passenger or driver side with the hood on.Its is real easy and if your careful you will not damage anything.I pulled mine about 1 1/2 months ago in about 3 hours.
Old May 1, 2005 | 09:04 PM
89corvetteken
Yes their are only 4 bolts.It can be done with the hood on but life is good working on the 89 with that monster off.
Old May 2, 2005 | 11:06 AM
Fatt Vette's Avatar
Fatt Vette
don't take it off unless you absolutely have to. The engine will come out easily over the side with the hood on. I have done it both ways, and I will NEVER take the hood off again!!
Old May 2, 2005 | 12:37 PM
RWDsmoke's Avatar
RWDsmoke
I just put a motor in my 86 with the hood on. More than enough room. I wouldn't take the hood off.
Old May 2, 2005 | 02:18 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
When I took mine off I used a silver sharpie pen and circled around each bolt/washer so I could put them back exactly in the same spot.
Old May 2, 2005 | 04:09 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Changed many motors and kept the hood on every time. Why make it more of a project than it needs to be.
Come in from the side and pull it out over the side. Its pretty simple.
Also leave as much on the motor as you can. I put nearly everything on the front of the motor I can when putting it back in. Saves tons of time and its easier outside the car.
I use a jack from the side to lift the car and it give you a little more room.
Check out the pictures in my website....
http://www.azzatochips.com/vettebuildup/434web.htm
This is the last one going in (the 434, everything I could bolt to it was on it.)
Again don't make it more of a project than it needs to be.
Old May 2, 2005 | 11:15 PM
Movnviolation
ski dwn it
Thanks for the pics. That will help. Thinking about pulling six spd. trans before pulling motor now.
Old May 3, 2005 | 02:11 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Default Pulling Your Engine
I'd suggest leaving the hood on, too. Removing the hood is definitely not a one person job, but I pulled the engine by myself. Lots of details . . . but it can be done. My Craftsman 9/16 swivel socket/end wrench became my favorite tool. Remove your wiper motor BEFORE you crunch it.
To Removing hood!
