Understanding diagnostic codes
Old May 1, 2005 | 06:44 PM
compulsivehp's Avatar
compulsivehp
Default Understanding diagnostic codes
I did a diagnostic scan and came up with these codes
Module 1 - H41
Module 4 - H67
The H67 is nothing but an A/C problem but i am confusied with the H41 code. Is it a CCM DTC or does it fall into the same catigory as the code H67 meaning its is teh ignition modual?
Old May 1, 2005 | 07:57 PM
Rebuilder's Avatar
Rebuilder
It is a CCM DTC. I don't have my manual available right now to look it up, however.
Rebuilder
Old May 8, 2005 | 09:50 PM
Rebuilder's Avatar
Rebuilder
DTC 41 is PCM serial data circuit loss of communications. The PCM is not responding to the CCM request for input. Could be a bad connection. Check the wiring & clear code to see if it comes back.
Rebuilder
To Understanding diagnostic codes
