On my new engine I got a breather on my passenger side valvecover. And the stock PVC vavle ( going to the intake ) on the driverside vavlecover.
When I take off the PVC vavle I see a slight amount of smoke coming out of the hole. Not much but its there, is that normal?
I can add, its thin white smoke..
you have to understand, the PCV is pressurized! It takes air from the TB and pumps it through the block, sucking bad stuff into the intake. It's a good system... and does it's job...
Ok thanks. But since I have installed the converted lt1 intake . I dont have a pvc vavle on the passenger side vavlecover, so nothing from the TB, i just use a breather there. The only place I use a pcv is on the driverside vavlecover, and that going to the lt1 intake.
