From: Sarcasm. Just one of the many services I offer.
Vette won't start-anti lock light comes on
Drove the vette for the first time in a month today. drove it around 15 miles or so around town. came back and parked it, about an hour later i came out to pull it in the garage. when I turn the starter it does one loud click and the ANTI-LOCK light lights up. with the brake not engaged the BRAKE and ANTI-LOCK light will light up when turning the key. voltage shows 12.0 volts.what is going on?
The Brake and Anit-Lock lights normally come on when starting my engine; so does the Low Coolant light. They go off after a few seconds.
None of those will prevent the engine from starting.
I suspect you have a low battery or a bad connection from the battery to the starter. A corroded terminal or loose connection at the battery would be the first thing I'd look at.
