Cable from the shifter?
Old May 3, 2005 | 05:44 PM
Carl Johansson's Avatar
Carl Johansson
Default Cable from the shifter?
Allright guys,
On an 86 coupe - we are very close to completing the swap from the 4+3 to the Tremek 500. Coming from the 4+3 shifter was a cable that headed forward into the center console - from there I don't know where it goes. (maybe hangs a left?)
What is it? does it need to get reconnected to the Tremek?
Any help is greatly appreciated!
Carl Johansson
Old May 3, 2005 | 06:46 PM
CFI-EFI's Avatar
CFI-EFI
We did this recently. It goes to the steering column for the transmission park lock feature.
RACE ON!!!
Old May 4, 2005 | 03:10 AM
4bblC4's Avatar
4bblC4
what are you doing with the 4+3? I'm interested!!
Old May 4, 2005 | 09:53 AM
Carl Johansson
RACE ON!!!
OK - so it engages some sort of lockout so you can't start the car in gear? that can't be right. So now I'm confused!
Whats the function Kenneth? and can I just do away with it?
Carl "sometimes I'm just plain stupid" Johansson
Old May 4, 2005 | 09:54 AM
Carl Johansson
I responded to the PM - thanks. I also read your other post - and I think you are probably on to something!
Old May 4, 2005 | 10:47 AM
ABNVET.I's Avatar
ABNVET.I
I just done this also but I went from a stock shifter to the B&M Hammer shifter. In the B&M Instructions it says to take the cable off and push the rod all the way up in the direction of the steering wheel. Secure it there. I put a hose clamp around it to hold it in place. Look at step 1 in the instructions it locks the steering wheel. http://www.bmracing.com/media/products/pdf/5.pdf
Old May 4, 2005 | 11:51 AM
Carl Johansson
Thanks for the info guys - I'll just move it out of the way and get rid of it when I redo the steering column.
To Cable from the shifter?
