how strong IS the 4+3?? (long)
I recently read this on a website regarding the history of the Muncie's and T10/Super T10's:
Muncie 4 speed transmissions were used in General Motors cars from 1963 to early 1975. These gear boxes were used when power levels exceeded the limits of the early Borg Warner T10 4 speed. It was actually based on the T-10 design and uses the same basic gear layout. The T10 made it's appearance in GM cars in 1957. From 1957 to 1963 many changes took place inside the gearbox to meet the increasing horsepower the new engines were putting out. It was replaced by the Muncie in late 1963. The Muncie 4 speed was used in production vehicles until power levels dropped in 1975. 1975 was the first year catalytic converters , smog pumps, and low horsepower were introduced. These new requirements led to the demise of the Muncie and the reintroduction of the improved T10 called the Super T10.
While General Motors was switching gearboxes around from 1963 to 1975 other companies such as Ford and AMC kept the T10 in production. So we got to see T10, and First Design Super T10 transmissions end up in these cars. It was also an opportunity for Borg Warner to design replacement Super T10's for the Muncie. These 4 speeds offered 9310 nickel gears, had a wide variety of gear ratios, and were available from any auto parts store carrying the Borg Warner parts line. A variation of this Super T10 ended up in GM cars from 1975 to 1983. Also as the 4 speed section of the 4+3 Corvette Overdrive in 1984 to 1988 Corvettes.
Well enough of this little 4 speed history. I figured I pass these facts on to you so that one day you can tell your children and just maybe all won't be lost. Lets face it today's muscle car is the Honda Civic. A majority of kids today will never feel the awesome torque of the big blocks as well as the feeling of ripping thru a few sets of gears.
My understanding is the 4+3 is a Super T10, with basically a small automatic transmission on the back of it. So I would think usually the part to break would be the overdrive unit. So why not take the OD unit off, put on a regular T10 Tailshaft, and just run the 4 speed? or better yet, run the 4 speed with a US Gear OD unit on the back of it?
Also, the original 4 speeds did not have a hydraulic system. they had a "linkage" that was basically a series of rods attached to the throwout bearing. How does the Corvette 4+3 throwout bearing work? I'm sure it's hydraulic.
What can be done to strengthen the 4+3 OD unit? Does it even come with a cooler, like any automatic transmission should? Can one buy better clutches for it, and up the line pressure, etc. like you would upgrade an automatic?
I'm just trying to learn more about a subject I'm so ignorant on. I am also looking to buy a 4+3 tranny, pedal assembly, and master/slave cylinder, AND have a recently rebuilt and upgraded 700R4 available for trade if someone is looking to switch.
Thanks for reading this!
2. Yes, it is a Super T-10 w/CC gear ratio combination.
3. Yes, the throwout bearing is hydraulically operated and non-adjustable.
4. Yes, the O/D uses the radiator as a cooler just like the automatics do.
5. Bronze clutch packs are available for the O/D, but are for seriously hardcore people.
6. Yes, the '87 B2K cars used the 4+3. They handled the torque just fine. I'm pretty sure Brian at S-K Speed did the work on them for Callaway and I do think increased line pressure was one of the items addressed.
Hey, if those older Super T10's and muncies can handle big block power, why can't an 80's Super T10 do it?
IMHO, if you dont drag race a lot, the 4+3 is a great tranny, I truely loved the 4+3
but,,,, if you pay to have teh 4+3 fixed once at @$1300, then it goes again, you will have already spent enough $$$$ to do a swap to another style of tranny.
Call the people that rebuild them and tell them about your application and they will tell you if it is adviseable or not.
If I were to do my swap again, I would do the TKO 600 / 5-speed.
I had no Idea that the OD used a cooler.
I would like more info on the bronze clutch packs, like where to get them, etc.
I'll give S-K Speed a call and talk to brian about the OD as well.
For those that think I am crazy, I'm not. I just can't afford to put in a 6 speed right now, and thought I'd at least give the T10 a try.
I plan on doing some things to the t10 itself to strengthen it up as well.
Keep it coming! thanks for the posts!
ALSO - I AM considering getting a t56 and fabricating the mount to get it to work. But that is another topic, and I will only be doing it if I can get a t56 for $700 or cheaper, in working condition. (I know, fat chance)
First of all, the 4+3 is NOT a super t10. the super t10 was only available as the aftermarket unit, and had a Iron case, and nickel gears.
In fact, the 4+3 t10 is actually weaker than some early models!
That being said, it is possible to get the 4+3 beefed up enough to work with a 475 horse motor, but that is the strongest they ever tested it to.
But THAT being said, he said it really isn't worth it. You would still have to be careful in shifting.
There are also the bronze clutch packs for the O/D unit available, but even with those you have to watch your shifting.
NOT A DRAG RACE TRANNY!
Brian also really dissed on the ZF6 Speed tranny, talking about how they have turned out to be a load of sh$t.
....... So much for that avenue. Guess I'll save up my pennies for a T56. Anybody have words of wisdom for me?
Though my 4+3 has been virtually trouble free (knock on wood) I'd swap to a richmond, keisler or ZF in a second if I had one of them in my garage.
please put up engine specs as well.
thanks all!
He bang shifts it all the time too...
now I KNOW that the 4+3 has got to be stronger than that toothpick of a tranny!
thanks all!
The times in my sig are on one run with the 4+3
Exactly, they do this for a livving! Same thing they told me
