L98 timing?
When I time my Vette, I let the engine get up to normally operating temperature, then with the parking brake engaged, I put the car in Drive, disconnect the EST and set the timing. When its set, reconnect the EST and you're good. I run mine at the stock 6.
I don't know if putting it in drive when setting it is necessary though...
How do u reset timing i would be intersted in doin 8 or 9 deg for my
highly modded 85, right now its set at 6 deg by my mech.
thanks sami.
except for on my 86, i usually run 10-12.
thanks sami.
thanks sami.
You should first bump the engine over until the TDC mark on the harmonic damper can be reached. Wipe off any grease and dirt and mark the TDC mark on the damper with something that will make it stand out and be easier to see. I use fingernail polish, but about anything will work, like chalk, yellow grease pencil, etc.
Warm up the engine then shut it down.
Disconnect the EST wire, which is a brown or tan wire with a black stripe located near the power brake booster. It's a single wire with a weather-pak connector; just separate the two at the connector.
Connect the timing light to the battery; red to positive and black to negative. Connect the other timing light connector to the #1 spark plug wire; anywhere along the wire will work. It just clamps over the plug wire.
Using the distributor wrench and, standing on the passenger side of the engine, loosen the bolt that holds the distributor hold-down clamp, which is located at the base of the distributor. Loosen the bolt just enough to allow you to turn the distributor.
Start the engine - it may be a little difficult at first but play with the throttle until the engine will idle on its own.
Point the timing light at the hamonic damper and pull its tiggger. The light will being to flash. On the timing chain cover there is a timing tab. These tabs are slightly different depending on the year of the car, but you should see numbers on the tab. Look at the mark you made on the damper and see which number the mark aligns with. That's your base timing. If the mark is aligned with 6, you have 6 degrees before TDC.
To change the timing, all you need to do is turn the distributor. As you turn the distributor (by turning the distributor cap) you'll see the timing mark move.
Once you have the timing where you want it, tighten the disributor hold down bolt, then recheck the timing to make sure it didn't move as you were tightening the bolt. If it moved, loosen the bolt again and adjust the distributor some more.
Once you have the timing where you want it, and the hold down bolt tight, shut down the engine, reconnect the EST wire and disconnect the battery for about 30 seconds. This will clear the error code that gets set when the ECM detected the engine running with the EST disconnected.
Reconnect the battery, remove the timing light connections and you're done.
Jake
Jake
and in details, may be u r good at typing soooo long sure it will help
the person who started thread and infact u made it easy a difficult job.
And not only u gave us confidence but also make it work.
sami.
Advancing it usually results in better gas mileage and more power at lower rpms. You will need to run a higher grade of gasoline.
Retarding it usually make your exhaust run hotter, maybe poorer fuel economy, makes lower rpms suffer, but lets you run lower octane gasoline.
Don't quote me on this. I just keep hearing it from other tuners in my area.
Think of it this way--when the spark fires before TDC, the mix is already starting to burn as the piston is finishing up its travel up the cylinder. At TDC, you've already got a good fire burning and pressure is rising quickly, pushing the piston down harder. If you advance your timing even further, the fuel/air mix has an even longer time to start building up pressure, meaning more pressure at TDC when the piston starts traveling down, and therefore even more power.
Downside of all is this is that if you have too much advance, the pressure and temperature get too high and you get detonation, similar to what happens with a high compression ratio. Also your NOx emissions go up because NOx levels rise with higher combustion temperature and pressure. It was pretty typical for automakers in the 70's to not add as much spark advance (as well as lower compression ratios) to lower NOx emissions, since the catalytic converters of that period didn't remove NOx emissions (NOx reduction is the 3rd part of a "three-way" catalytic converter).
Also, theoretically you could start having misfires from having too much advance, as the fuel/air mixture isn't compressed enough to light off. But, I've never run into that happening--typically you'll get detonation before you hit that point.
Finally, bumping up the advance shouldn't move the powerband around--it should increase power at all RPMs, although the effect isn't as noticable as at high RPMs since at higher RPM you're already running around 35 degrees of spark lead--a couple extra degrees of advance doesn't affect things as much as at low RPM when you've increased the lead from say from 6 to 8 degrees (a 33% increase of spark advance).
Hope this helps!
Ben
If you advance too far you might hear ping at WOT and high RPM or the ECM may detect ping and pull timing before you can hear it.
You can find the optimum point at the strip or with a scan tool. The former will show optimum timing by best trap speed (if you are consistent) and the latter will show knock counts and the ECM pulling timing when advance it a little too high.
