pulling codes on a "90"?
Old May 5, 2005 | 12:32 AM
Shawn_65's Avatar
Shawn_65
Default pulling codes on a "90"?
just need to figure out how to pull codes on my 1990. A quick reply would be awsome. Heard u have to use a paper clip or something..?
i dunno im a noob
Old May 5, 2005 | 11:03 AM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
use a paper clip and jump connections A and B on the ALDL under the drivers side area.
Turn the key on and the check engine light will flash in morse code... a 12 is normal, it means it's working. to flash a 12 it will flash the check engine light once, then twice. It will repeat each code three times...
so if you had a code 34 the check engine light would flash like this after turning the key on:
Flash - Flash Flash (this is the 12, the - is a slight pause)
Flash - Flash Flash
Flash - Flash Flash
Flash Flash Flash - Flash Flash Flash Flash
Flash - Flash Flash
Flash - Flash Flash
Flash - Flash Flash
go give it a try and you'll see.... a service manual sounds like a good addition to your library, it has all kinds of cool stuff like this in there.
It will repeat between the 12 and the other codes until you pull the connector or turn the key off. The fan running while you do this is normal as well.
Old May 5, 2005 | 11:05 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
1) Pencil & Paper At The Ready
2) Key Off
3) Short Pins A&B OnThe ALDL
4) Key On (Do NOT Start The Engine)
5) Count the Flashes (Check Engine Light) & Write Them Down
6) Key Off
7) Unshort Pins A&B On The ALDL
The First Three Flashes Will Be 12,12,12,
Followed By Three Flashes Of Any Stored Codes
Finished By 12,12,12
If all you get are 12's then you have no MIL Codes Stored.
Example: Code 32 Stored:
12,12,12 32,32,32 12,12,12
Do a search for ODBI codes to decode the ones, if any, you have.
Or post them here.
Old May 5, 2005 | 10:00 PM
Shawn_65's Avatar
Shawn_65
Awsome guys, way to help us noobs
To pulling codes on a "90"?
