Failing Thermometer
Old May 5, 2005 | 02:45 PM
pologreen91's Avatar
pologreen91
Default Failing Thermometer
Where will I find the outside temp. thermometer? Mine appears to be stuck at 54 degrees
Old May 5, 2005 | 04:05 PM
odysseysteve's Avatar
odysseysteve
I have often wondered (yeah, I know...) where that is located. Bump for ya.
Old May 5, 2005 | 04:16 PM
BlackbirdZ07's Avatar
BlackbirdZ07
The outside air temp (OAT) sensor is under the nose of the car, in the radiator air intake area. If you get under the front of the car and look on the passenger side of the air intake area you'll see a small rectangular black plastic box. It is mounted to the passenger side of the air intake area. The front and back of the box have a plastic sceen to let air flow through. You can see the OAT sensor in this box if you use a flashlight.
I've had a similar problem with the OAT "sticking" on one temp. I think I found a way to fix the problem. Due to its location the OAT sensor gets a lot of road grime on it, especially if you drive the car in rain. Mine seems to work fine after a good cleaning. I used cotton swabs soaked in clean water, and stuck them through the screen holes in the plastic box to clean the sensor. It's hard to see and hard to get to so it takes a bit of time and patience. Be sure to clean the front AND back of the sensor, and be gentle with it.
Cleaning the sensor seemed to fix the problem for me, and I'd be very interested in knowing whether this works for others as well. Try cleaning yours and please post back and let me know if it works.
Old May 5, 2005 | 05:36 PM
Steel Blue 91's Avatar
Steel Blue 91
I will give this procedure a try since mine seems to be a little slugish at times.
Old May 6, 2005 | 11:00 AM
pologreen91
I'll give this a shot too. Funny on the way home yesterday about 10 minutes out it started showing an accurate temp. again.
Old May 6, 2005 | 03:36 PM
BlackbirdZ07
That's exactly what mine would do... it would stick on a certain temperature and then start working ten or twenty minutes later. Let us know what happens when you clean the sensor.
Old May 11, 2005 | 04:11 PM
pologreen91
I haven't tried this yet, because the thing appears to be working for the last 4 or 5 days. I'll keep my eye on it and try it
when I see it stick.
To Failing Thermometer
