Calling all McLeod Street Twin users!!!
Old May 6, 2005 | 10:29 PM
LT4POWR's Avatar
LT4POWR
Default Calling all McLeod Street Twin users!!!
I'm thinking about getting one and have some questions.
Which flywheel did you get?
How bad was the noise?
Did you break any driveline parts after using it?
What tires were you using when the breakage occured?
Would you recommend it?
Old May 6, 2005 | 10:33 PM
luvmy92's Avatar
luvmy92
I went with the steel SM flywheel because it's still driven on the street.
The noise is very minor... once you're moving it's unnoticeable.
No driveline parts broken yet but I don't drag race
It's tough to launch with a manual but I have no complaints. Running at Sebring for the first time with it next weekend.
Mike
Old May 7, 2005 | 10:38 AM
tpi 421 vette's Avatar
tpi 421 vette
I'm running a street twin with the aluminum flywheel in mine. I run ET Streets full time. Mine idles a little high, about 1100 rpm, that and it's kind of loud, so I can't really hear the flywheel make noise. But I can tell you that I never broke parts with a single disc. And after I put in the dual disc... I broke 3 halfshafts, a U joint, and broke a D44 housing in half.
I don't think I will break anymore parts now
Old May 7, 2005 | 12:41 PM
thetoy's Avatar
thetoy
I am also running the street twin with the aluminum flywheel and run the ET streets most of the time. Mine does make quit a bit of noise at idle but its worth it becuase none of the other clutches have lasted very long. I also have broken two half shafts, a spindal, And tore the D44 in half the first time at the drag strip. I have learned how to launch now with this clutch and its working great.
Old May 9, 2005 | 09:53 AM
LT4POWR's Avatar
LT4POWR
You guys have me a little worried about breaking driveline parts...I guess the rumors are true. I was thinking that I shouldn't break anything as long as I run my old bald/hard street radials What do you guys think? Right now I'm leaning toward the aluminum flywheel. Any others out there?
Old May 9, 2005 | 11:31 AM
TrueBlue ChevyDude's Avatar
TrueBlue ChevyDude
From: Brandywine, Chester and Ridley Valleys Pennsylvania
Never had a breakage problem, running BFG drag radials, current setup nearly 500 chp, prior to that a 675 chp setup. I'm running a steel flywheel.
Great clutch, though I know sometimes it's possible to shock the driveline with an inadvertent full release, it can be a bit grabby until you get the feel of it.
Old May 9, 2005 | 11:46 AM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
was running the aluminum flywheel with the twin disk setup, with m&h's. took out both half shafts and a spindle, but thats a problem with sticky tires, not the clutch. the clutch let everything hook up without slipping. i've taken mine out of the car as i went back to stock and cannot run the aluminum flywheel in this class, and its for sale.
Old May 9, 2005 | 11:48 AM
ninetyfivevette's Avatar
ninetyfivevette
I have the aluminum flywheel with my Twin. Noise is pretty bad, but my c-beam was loose, so now that it is tightened back up it won't be so bad. No broken parts yet, but I also don't dump the clutch with my little D36.
Old May 9, 2005 | 12:23 PM
jburnett's Avatar
jburnett
SEVERAL Street Twin here... I've used George and Red's twins for a long time on several different cars and always had great luck with them. My 9.91 was with a Street Twin. I've used both steel and aluminum flywheels; I prefer the aluminum because most of the motors I run are N2O or big strokers (or both) and they DON'T NEED the moment of inertia that the steel flywheel will give. They are also easier on driveline's IMO. I've always had stellar luck with my driveline (even before the cryo-business) except for drive spindles, they were the only thing I routinely broke. I ran 28x11.5x15 ET Streets and 28x10.5x15 ET Drags; and left at 5500-6000 rpm. The harder I hit the tires the less things got broken...
-Jeb
Old May 9, 2005 | 03:04 PM
LT4POWR's Avatar
LT4POWR
-Jeb
I was hoping you would reply…I thought about e-mailing you directly. Once I get a few things sorted out, I’ll be contacting you to get some price quote/s regarding doing some cryo work. I’ve decided that if I get a street twin right now, I’m going w/ the aluminum flywheel. I still haven’t put my car back together yet.
Are these good prices?
Part #64023-1A-07 Stl. Fly. - $1079.00 Shipped
Part #63023-1A-07 Alu. Fly. - $ 1219.00 Shipped
Old May 9, 2005 | 04:37 PM
luvmy92's Avatar
luvmy92
I got mine from TByrne for right around $1000 shipped I believe (Steel flywheel), and the Alum Flywheel was like $1150.
Mike
Old May 9, 2005 | 05:11 PM
jburnett's Avatar
jburnett
That seems about right for pricing... You can find the aluminum setups between $1100 and $1200 usually with the steel ones coming in under $1k occasionally. I usually buy my mine directly from McLeod.
I'll be here to answer your questions, LT4POWR; just email me or PM me whenever you'd like.
-Jeb
Old May 9, 2005 | 08:14 PM
ASRoff's Avatar
ASRoff
Street twin with drag radials nothingg broken so far. (62 passes and counting)
Old May 10, 2005 | 09:52 AM
SonnyinVA's Avatar
SonnyinVA
i don't know if i'd recommend the SPEC clutch, but their aluminum flywheel is about half that $$$...
see ya,
sonny
Old May 10, 2005 | 11:05 AM
91tpi-zf's Avatar
91tpi-zf
I ran the "race twin" setup for a couple of years. It is similar to the street twin, but each of the clutch disks has one side kevlar and the other is organic(factory style). It also uses the Borg and Beck "push" pressure plate with a hydraulic throw out bearing bolted to the tranny. It was a little noisy at idle, but never slipped even with 833rwhp. Ran some easy launching (1.55 60') 9.8's with this setup.
The only thing I ever broke was the clutch itself, as it stripped the organic facings off both clutch disks, and a half shaft on a 1-2 shift. I found out that if I would preload the driveline before launch, I could avoid breakage.
I now run an automatic
Old May 10, 2005 | 03:48 PM
LT4POWR's Avatar
LT4POWR
How'd you go about doing that?
I’m basically looking for a street/strip clutch that will handle around 425-450rwhp....there also might be a small N2O shot or stroker motor in the future. I plan to run drag radials on the street and slicks on the strip. Unless I can develop a better method, I need something that will take high rpm clutch drops at the strip. I think I should probably plan on upgrading the driveline before I try slicks at the track.
Old May 10, 2005 | 05:19 PM
91tpi-zf's Avatar
91tpi-zf
Line lock on the front brakes, and take up the slack in the clutch pedal until the car seems like it is almost wanting to move. Then a quick release of the clutch pedal when the light turns green.
To Calling all McLeod Street Twin users!!!
