96 LT1 Opti replacement problems
Old May 7, 2005 | 05:43 PM
mstolars22's Avatar
mstolars22
6th Gear
Default 96 LT1 Opti replacement problems
Hi, I have a 96 collector's edition LT1 engine and I'm getting really frustrated with the Opti change. I pulled the water pump out, crank pulley and got the old Opti out, now I pretty much trashed the old one while removing it.
I ended up picking up a reman Opti from a local parts place, along with a new cap (trying to save a few bucks staying away from the dealer). Now after assembling the new opti and installing it on the cam, it seems like it's sticking out a few millimeters from the block where it bolts down. It seems like it's on there and I was able to tighten the bolts just fine, but when I went to plug in the connector for the Opti, I can't get it to click in.
I went so far as taking it all apart again and tried plugging the wires in without the distributor installed, still doesn't snap in. I then took the Opti apart all the way and tried plugging in the wires directly to the opti sensor, it plugs in fine, but when I put on the white plastic peice where the plug is supposed to lock on, it won't fit, it goes almost all the way, but then stops before it gets to the lock. Can anyone help me out with this?? Thanks in advance.
Old May 7, 2005 | 06:25 PM
Bruce's Avatar
Bruce
I spent about $600 for the Delteq. I will never have to replace the opti crap again. Take a break and slow down. Go over everything. Remenber, it will only going one way. If it does not go in don't force it. Perhaps thing is not line up.
Old May 7, 2005 | 06:26 PM
MikeC4's Avatar
MikeC4
Wow!!! STOP what you are doing NOW!! It sounds like you do not have your Optispark "keyed" correctly. You need to line up the index groove(see pic) to the steel pin sticking out of the cam. You should have NO PLAY whatsoever once you have mated your Opti properly to the front of your engine. Stick your head in the engine bay to see the relative position of the pin on the cam, then turn the Opti shaft to get the indexed groove to be in the relative position of the cam pin. Then take the Opti and carefully mount. If you don't get a flush seating, remove the Opti and turn the shaft a little to reposition the index groove. You may have to do this 3 or 4 times before you get the cam pin to seat into the index groove. But when you get the Opti seated correctly, you will know it. I hope you didn't tighten the 3 Opti bolts too tight, as this could cause the aluminum housing to get deformed!!!??????
As far as the connectors, you may have broken the little lock clips, so you won't get a "click" sound when you install. You should be OK if the connectors mate tightly...If not you may have to buy new connectors and cut the old ones off and splice the new ones on... But I doubt you will have any problems with the connectors the way they are.....
Old May 7, 2005 | 08:19 PM
mstolars22's Avatar
mstolars22
6th Gear
Well, when putting on the connector, it doesn't lock in, and the lock is still there, it won't go on far enough to lock it down. And, if let it sit where it's at in the connector, it just pops out by itself. I'm so frustrated with it that I'm ready to take a hammer to it to get it to seat further down in there I'm going to try seating the distributor to cam without the dizzy cap on so i can rotate the rotor to line it up better.
Old May 7, 2005 | 09:59 PM
MikeC4's Avatar
MikeC4
If you can not get the 4-pin connector on, there is a good chance that you may have bent one of the 4 pins in the Optispark recepticle. Take a flashlight and look in your Opti connector, as these 4 pins are deep inside. If you did bend one, you may be able to straighten it with a pair of needle nose pliers, but be careful when doing this.....
As far as alignment of the Opti index groove and the cam pin, you just need to excersise a little more patience...If you do install it with the dist. cap off, be careful not to get any gunk on the rotor, and keep an eye on the rubber gasket, making sure it stays firmly seated.....I assume you have the proper inverse torx bit for the 4 screws that attach the dist. to the Opti unit.....
Old May 7, 2005 | 10:20 PM
okies93's Avatar
okies93
St. Jude Donor 06
the car is junk and not any good. wanna sell it?
LOL
Old May 7, 2005 | 10:35 PM
MikeC4's Avatar
MikeC4
BTW, how did you trash your old Opti when simply removing it? Nothing I can think of while performig this job requires any heavy handed crow-barring...????
Old May 8, 2005 | 12:29 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
You think yours is tough try a 93 with our geared spline wit a 2 tooth key to match up.Paitence is a virtue here. When you get it right it will "pop" onto the timing cover and be flush with it keep at it you will get it.
Try some Die electric grease in the plug. You should always use a little when working with Opti plugs and plug wires.
Old May 8, 2005 | 01:47 AM
mstolars22's Avatar
mstolars22
6th Gear
Pins are fine, like i said in the first post, if i take the distributor all apart i can plug the wires directly onto the pins, but when I put the white outer part on the distributor the connector won't lock in, it's like the plug is too long or something. Also, the old distributor got trashed from trying to get the crank pulley off with 2 pry bars between the distributor and the pulley.
Old May 8, 2005 | 08:04 AM
99svrcpe's Avatar
99svrcpe
I know what your going through. I had the same problem a few years ago when I changed an opti. It can be a PITA sometimes to get the cam pin lined up properly. It should fit perfectly flush against the timing cover. Goodluck
Old May 8, 2005 | 09:42 AM
Strick's Avatar
Strick
This is a good example of using the correct tool for the job. You need a Kent-Moore LT1/4 crank hub puller and installer. Take a look at the tech tips section and look for an article "How to install a Meziere coolant pump" It has a section that describes the removal and installation of the opti. Oh, I hate to tell you this, but I haven't heard of anyone who has had good luck with a reman opti. With the amount of work you do to replace it, you should, at least, install a new one and I'd even upgrade to the Dyna-spark from Dyno-Tech Engineering <=
Old May 8, 2005 | 01:04 PM
mstolars22's Avatar
mstolars22
6th Gear
AHHHH! I did all that stuff allready, all I can't do now is plug in the wires for the opti sensor. Thanks for all the help and all, but I keep reading the same posts and it's driving me crazy Please don't take offense to that, but after trying to put that plug in for over 3 days, I'm in another world and ready to just sell the car so I don't have to worry about it anymore.
Old May 8, 2005 | 02:43 PM
bogus's Avatar
bogus
uh, can't get the plug in? it only goes in one way... make sure you are lined up properly.
Old May 8, 2005 | 04:11 PM
pwrful c4's Avatar
pwrful c4
Iam spending the money for the Deltag system.I think my ignition worries will be over.I have read many posts on the opti and the remanafactured is not the way to go.I have also seen a opti go out in 8000 miles.
Old May 8, 2005 | 04:35 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Doesn't the Delteq unit use/need the Low resolution signal from the Optispark?
Old May 8, 2005 | 07:42 PM
mstolars22's Avatar
mstolars22
6th Gear
Hmm, this Delteq system has me intrigued. I wonder, is there a way to do away with the actual optispark distributor and use some other sensor in its place?? It seems that you still have to use the optispark distributor when you install the delteq. So, if the waterpump decides to take a dive again, the optispark will go out again, and it won't matter if you have the delteq.
Old May 8, 2005 | 08:03 PM
Redeasysport
Mod your water pump like I did and it will never dump on the opti look in my gallery for a pic.
You should be able to peel the opti layers off and use your old ring with the plug in it as long as it is not totally carbon traced you can clean it with electrical cleaner.It also pays at this point to use some RTV Hitemp and seal each layer of the opti as you re assemble but you wont be able to take it back if you do this I believe(mabey not?).
If it still won't go on take it back it is junk. So try pluggin it in before sealing the Opti. As was already stated above some things on a vette you can get for cheap others it pays to stay with OEM or better and remans are prone to failure on this item. So good luck with the opti.
Old May 8, 2005 | 08:44 PM
rwsduc's Avatar
rwsduc
When the waterpump goes out (or upper radiaditor hose blows out) it typically takes out the high voltage side of the opti. I went with a Delteq after my opti got wet and continue to run with the same old opti in place. The low voltage optical side is still doing just fine, and I know there are quite a few others on here running a Delteq system that are in the same boat as I am. Will my opti EVER need to be replaced? Probably, afterall it's mechanical and I'm told that over time the antifreeze will effect the internal bearing and eventually cause the optical disc to wobble and start throwing codes. Until that happens, I'm not going to worry about it or debate the merits of Delteq, I'm just going to drive the PI55 out of it!
To 96 LT1 Opti replacement problems
