Richmond vs. Keisler
Old May 7, 2005 | 07:43 PM
Ray383's Avatar
Ray383
Default Richmond vs. Keisler
I have decided that while I'm at replaceing everything in my engine bay, its time to replace my 4+3 speed. I had originaly wanted to just rebuild the 4+3, but for the amount of money it would cost I might as well step up to a better tranny. I have always wanted to put the Richmond in. Now I'm hearing about the Keisler tko 500 and 600. I would like to have the car finish in 1 month.
If you had both trannys in your garage, which would you install? Anyone know the delivery time on the Keisler?
Ray
Old May 7, 2005 | 07:50 PM
LPDesRoche's Avatar
LPDesRoche
If I had both trannys sitting in the garage, I would go with the Keisler for sure. They use better trannys any way you look at it. I hear they are a bit slow on the shiping though. At least thats what has been posted here, maybe they are up to speed now.
Old May 8, 2005 | 12:42 AM
Steve85's Avatar
Steve85
Cruise-In V Veteran
I have the Richmond and generally, it seems very strong, but the shifting is bit jerky (not as smooth as I would expect) and the throw is long, especially for an aftermarket tranny.
You can choose gearing with either one, MAKE SURE you take advantage of this. If your raising the RPM range of the motor go with steeper gearing, you won't have to touch your rear gears then.
The Keisler for the C4 is a newer design and more than likely a better design.
Old May 8, 2005 | 12:53 PM
Ray383's Avatar
Ray383
Thanks for the advice. I will be looking into optimal gearing for my 3.07s. I shoot Keisler an email to find out how soon I could expect a 5 or 6 speed kit. The Richmond could be here in a week and a 1/2.
Old May 8, 2005 | 01:45 PM
Dartvader's Avatar
Dartvader
The word is that the Keisler is smoother shifting, but the Richmond is stronger. How are you going to use the car. In daily driving, the Keisler would be more user friendly. How high are you going to build the engine? Is it going to be high horsepower? They are really nice guys, but Keisler is really swamped with orders, and inquiries. Three years ago, they helped me put a 5 speed behind a turbocharged Mopar slant six. They were prompt, helpful, and shipped quickly. Last year I investigated putting a 5 speed behind my 360 Dart 4 spd, and it took them several weeks to answer my e-mail. It will be interesting to see if they have caught up yet. Keisler has gotten alot fo publicity lately with articles in the press, and I don;t think they were ready for the barrage of responses that has come there way.
Old May 8, 2005 | 02:36 PM
Ray383's Avatar
Ray383
The motor is an all forged 383, 219, superram, warmed over 200cc protopline alum. heads, and a 150-300 hp direct port setup. I've never drived a car with this much power NA, so I don't know if or when I'll be hitting the gas. The tko has a higher advertised torque rating than the Richmond, but take that for what its worth.
Old May 8, 2005 | 04:03 PM
Robert Hall's Avatar
0Robert Hall
Former Vendor
Default The TKO IS Definitely Stronger than the Richmond! 6-8 weeks delivery.
Hello All -
We have sold several hundred of the new TK0 500 and 600 kits and have found them to be practically bullet proof, and we have customers running them in Supercharged, Big Block, Hemi Mopar drag cars!
At present we're about 6-8 weeks out on TKO kit deliveries, but they are truly worth the wait.
Also remember our 6 speed kit goes into production soon. I've driven an '87 with our 5 speed and then later with our 6 speed. You really couldn't ask for two sweeter trannies.
Robert Hall - Keisler Sales
423-773-9789 Direct
865-609-8187
Old May 8, 2005 | 08:00 PM
Ray383's Avatar
Ray383
Sunds like a great tranny, but 6-8 weeks = half the summer. And then 6-8 has a way of turning into 10-12...... I also thought the 6 speed was already available.
Old May 8, 2005 | 08:53 PM
Dartvader's Avatar
Dartvader
I read Bob's post again, and it sounds like the 6 speed is ready now. Maybe I read it wrong.
Old May 8, 2005 | 08:54 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Mr Hall, is the six speed going to have double overdrive like the ZF's have or will it be like the Richmond that has 1:1 for 5th gear and only one overdrive?
Not that I need one, but I thought I'd ask.
Old May 8, 2005 | 09:19 PM
Ray383's Avatar
Ray383
Doesn't sound like its available yet.
Old May 8, 2005 | 11:24 PM
0Robert Hall
Former Vendor
Default 6 Speed
We have had a 6 speed for C3 for a year or two, but have not released the C4 kit for sale yet.
The C4 6 speed will have 2 o/d gears.
We already have our C4 6 speed test car back in the owner's hands, and I'll see if I can get a product launch date for you in the next few days.
Robert Hall - Keisler Engineering sales
Direct Line 423-773-9789
Main number 865-609-8187 ext 280
1966 327/300 Factory A/C
Keisler 5 Speed Vette #001 !
Old May 8, 2005 | 11:28 PM
Mr Mojo's Avatar
Mr Mojo
Old May 8, 2005 | 11:31 PM
bogus's Avatar
bogus
I would go Keisler... infact, the Tremic it's based on might be a viable replacement for the ZF6...
Old May 9, 2005 | 04:02 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I'm still curious what turned you off from rebuilding the 4+3...
Parts cost? Labor cost? (How much $$?) Are you rebuilding both units, (do they both need rebuilding?)
Old May 9, 2005 | 04:04 AM
CentralCoaster
This thread is probably worth a read if you haven't already...
I'm still making my way through it.
http://forums.corvetteforum.com/show...20&forum_id=48
Old May 9, 2005 | 04:17 AM
Ray383's Avatar
Ray383
I cracked the tail housing, and second gear is shot. If it wasn't cracked the od would be fine, but the welding would require a rebuild or at least a tear down. $1300 without the welding. Can't see putting that kind of money iinto a 4+3. I really wanted to see how much power the 4+3 could handle. For $6-800 I would, but for $1600+, its time to step up.
Old May 9, 2005 | 06:14 AM
Fubar569's Avatar
Fubar569
this almost makes me wanna try to convert the 84 to a standard, but it's probably too much trouble...plus i already bought the flexplate for the engine...
To Richmond vs. Keisler
