Spare Tire Carrier Bolt
Old May 8, 2005 | 10:26 PM
aj1988's Avatar
aj1988
Default Spare Tire Carrier Bolt
To who ever made the post about taking out the license plate - Thanks.
Also, if you have never cleaned the bolt you might want to do it before it rusts in like mine did. Not having a vice I had to use vice grips on the end and stand on the tube and the fight the bolt out with a 1/2 " ratchet. Took about 20 minutes of serious fighting to get the bolt out. Cleaned it and lubed it and it goes in really easy.
Old May 8, 2005 | 11:55 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Not sure if it was me that mentioned removing the license plate, but that has always been my recommendation.
Old May 9, 2005 | 10:36 AM
jodyeastman's Avatar
jodyeastman
I Can't get mine out. I have a long 316 SS bolt machined to replace it with anyway. It will match my corsa system better. I'm just gonnea cut it off.
Old May 9, 2005 | 11:12 AM
aj1988's Avatar
aj1988
Unless you have another tube that isn't going to work. The factory bolt is about 6 inches long and if it is rusted I would suggest pulling the entire assembly and clamping the top into a vice and get after the bolt with a 1/2" ratchet (socket is 19mm). I kept spraying WD-40 in about every 1/4" of the bolt I got out. Not fun with vice-grips and having to hold it down with your foot.
To Spare Tire Carrier Bolt
