Alky nozzle placement question
Old May 8, 2005 | 10:33 PM
qwiketz's Avatar
qwiketz
Default Alky nozzle placement question
I have my setup 90% installed. All I have to do is put some flex loom wire covers over the wires and mount the nozzles.
I was wondering if it's a problem to be spraying in very close proximity to the sensore in the blower discharge tube. I was thinking of placing my two nozzles side by side in the middle of the dischage tube about 1" before the sensor and about 1" after the blow off valve.
It seems like everyone's nozzles are mounted there. Any problems with that?
Old May 9, 2005 | 07:26 PM
Mo_Bandy's Avatar
Mo_Bandy
Quiketz,
That should work fine, that is roughly where I have mine. Look at my site I have some fairly good pics of it...
It hasnt effected my sensor readings at all.
Mo
Old May 9, 2005 | 09:06 PM
qwiketz's Avatar
qwiketz
awesome. I'm going to mount it tonight. Everything has worked out totally awesome so far....
Old May 9, 2005 | 10:12 PM
Mo_Bandy's Avatar
Mo_Bandy
Did the picture on the website help?
Mo
Old May 10, 2005 | 02:39 AM
qwiketz's Avatar
qwiketz
Definately did help.
My setup looks pretty similar except it has two nozzles side by side. It also uses a gasket type setup with a fitting going through. I'm going to start with the 7 and 11 gal per hr nozzles installed. I'm going to setup the controller to only provide the full 18 gph at 10 lbs of boost (which probably will only happen at the track when I prep the belt with vht).
I'm excited to try this out! I'll probably fire up the car tommorrow once I clean up the wiring.
I'll try to post some pics over the weekend.
Old May 10, 2005 | 02:10 PM
Mo_Bandy's Avatar
Mo_Bandy
Sounds good!
Mo
To Alky nozzle placement question
