Half Shafts
Old May 9, 2005 | 11:02 AM
TODDZWER's Avatar
TODDZWER
Default Half Shafts
I am in need of some good half shafts. Friday night I twisted both of mine until they snapped so I also need some help as to exactly how long they are for an 89 with dana 44. Does anyone have any better choices for shafts(built 383 with 478 rear end) factory was not the answer.
Old May 9, 2005 | 11:14 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
www.dennysdriveshaft.com
Old May 9, 2005 | 11:15 AM
65Z01's Avatar
65Z01
If no leads here you might IM Vic'89 as he had a similar fate with his '89 a copla years ago.
He's pulling pretty good short times and running in the mid 12sec range but I don't know what half-shafts he replaced with.
Old May 9, 2005 | 11:28 AM
CFI-EFI's Avatar
CFI-EFI
FYI. All C4 half shafts are interchangeable.
RACE ON!!!
Old May 9, 2005 | 11:43 AM
Steel Blue 91's Avatar
Steel Blue 91
Here ya go. Carbon fiber half shafts.
http://vansteel.com/Corvette_Parts/8...Parts_2233.cfm
HS-8496C 1984 -1996 Carbon Fiber Half Shafts $600.00 pair.
Old May 9, 2005 | 11:50 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
That is WAY too much gear...hence the reason your breaking your 1/2 shafts.
Old May 9, 2005 | 12:19 PM
scorp508's Avatar
scorp508
A 4.78 rear gear? I didn't even know anyone manufacturered a gear that short for a vette D44. Get some more slippery tires!
Old May 9, 2005 | 12:56 PM
4bblC4's Avatar
4bblC4
What's your 60', todzwer?
Old May 9, 2005 | 03:01 PM
TODDZWER's Avatar
TODDZWER
not sure never got that far
Old May 9, 2005 | 07:59 PM
Vic'89's Avatar
Vic'89
Actually I replaced my broken half shafts with new stock half shafts and new Spicer U joints. So far after 2 years, they are running strong.
BTW, that 4.88 gear you have is way overkill in my opinion.
Vic
Old May 10, 2005 | 12:34 PM
red L98's Avatar
red L98
wow thats a fun gear if it hooks and dont break
Old May 10, 2005 | 12:43 PM
91tpi-zf's Avatar
91tpi-zf
I have ran 1.3x 60's with Dennys Driveshaft Halfshafts.
scorp508's Avatar
scorp508
Oh man... I was there that day. I couldn't believe he twisted BOTH of them into pretzels on the line.
Old May 10, 2005 | 01:10 PM
Fubar569's Avatar
Fubar569
red, what rear end is in your car now?
Old May 10, 2005 | 06:49 PM
red L98's Avatar
red L98
i have the car creations new dana 44 , spool, 3.92 . i also have dennys halfshafts. i did few extra things to help the Dana 44 live longer i plan on posting pics friday when it all done . i also now run coilovers and a th350 so it should help .
Old May 10, 2005 | 06:57 PM
Baldturbofreak's Avatar
Baldturbofreak
I wonder what those carbon jobbies are rated for.
Lets see 1000ft/lbs or torque x First gear x 3.45 rear end - oh my I just scared myself.
Old May 10, 2005 | 07:35 PM
red L98's Avatar
red L98
i think Thetoy used them with his 434 ci motor and twist them both in half the first day out with them
To Half Shafts
Old May 10, 2005 | 07:45 PM
Baldturbofreak
Well since Im in the middle 'O stress analysis class, I think I 'll do some calcs on torsional/shear loads for a aluminum shaft. anyone know what the wall on the halfshafts are?
Old May 10, 2005 | 08:47 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I've never broke a 1/2 shaft in two but I do brake my share of u-joints and that tears up the shafts. I think my problem is my car squats pass level and put the u-joint at a bad angle and they snap.
Old May 10, 2005 | 10:58 PM
thetoy's Avatar
thetoy
You are correct I did break both of my carbon fiber halfshafts the very first time out with them. They did refund my money since i only had them for a week. I have since then gone back to the stock half shafts but now i just baby it off the line then hammer it! There also alot cheaper to replace then everything else back there.
