Best engine mods for a stock L98??
#81
Originally Posted by TheStef
I think a lot of these older L98 cars had their engines and tranny's rebuilt and the truth of the matter is... I think some of us don't even know what we have in your own cars.
I do believe that some Vettes out there will outperform others just for these simple manufacturing reason.
I'm not expert in cars but I've read enough to know what I said are facts... and this might explain some of those "super vettes" out there.
This was backed up by a 13.87 run at 98 mph with no mods. I do agree that some car are faster than other right from the factory, but all of these L98 will respond to exhaust and intakes mods.
Vic
#82
Originally Posted by Mad-Mic
for someone that don't crack on his car at ALL i guess you just have the time to sit around your driveway with the hood open and sit around with a volt meter all day testing sensors to see "How" your car is running "Perfect".
My data logging equipment is probably rather more powerful than most too and I can record engine parameters when driving the vehicle to monitor mixture and other sensors.
This thread went this way because you proclaimed that Bosch Platinum plugs were 'Junk' - I disagreed and told you why I disagree. I still do. You claimed that your car ran so rich that it caused Bosch Platinum plugs to foul up after 6k miles but your AC Delcos are just fine. I stated that is not normal and there must be another factor involved.
You then added that you have LT headers with an unheated O2 sensor - now I know why you killed your Bosch Platinums - you never reached CLOSED LOOP and so your car would run very rich - go figure.
#83
Plugs don't foul at WOT, they Foul when the engine is off and they cool. learned that one racing dirt bikes as a kid.
4 stroke motors do not carbon up when the engine is cooling - there is nothing in the cylinder to cause carbon to form. 2 strokes have residual oil in the cylinder that burns onto the plugs.
4 stroke motors carbon their plugs when they are running very, VERY rich or when they are burning oil. In fact they would have to be so rich that they would wreck the cat due to unburnt fuel igniting inside, leave black soot up the pipe and all over the rear bumper and you would sure as heck fail sniffer tests.
#84
#85
Hmm, actually yes I do. I have spent 4 years analysing ECU systems and have written a 600+ page web site about a specific European vehicle which includes extensive analysis of engine performance and OBD2 systems. I also have access to the Ford Motor Company archives and databases. All I'm saying is that I'd like to think that I know a little about what I'm talking about.
BTW you questioned me where i got my information and i answered. your information does not support what you are trying to debate about plug fouling. AF Ratio on a dead idling car with 0% throttle is high enough so no plug should ever foul. so where does fouled plugs come from if the combustion temps are so high to burn any excess fuel off?
#86
Hmm, and I'll bet they were 2 stroke motors
state standards Inspection readings
hydrocarbons
220 ppm 531 ppm fail
carbon monozide
1.20 pct 1.11 pct pass
carbon dioxide
6.0 pct 13.38 pct pass
when i go back this month i'm sure she'll pass right through even with 12 degrees timing. once i finish the 388 up i'm putting 2 3" hi flow bullet cats cause i'm going with an LT1 style true dual setup.
now i'm curious how much did the MAF relays and the O2 threw it off by. i'll keep you informed.
#87
how can you tell what gear ratio your rear end is? and with a torque converter how does a higher stall speed help your car? i dont know exactly how the torque converter works
#88
We should probably let this thread die as neither of us is going to agree - I like my Bosch Platinum+4s because they suit my Vette and you prefer Delcos cos they suit yours. I just guess that the motors are different in some way.
By the way, if you are getting a constant 12.9 AF ratio then you have a problem as the ECU constantly varies the AF ratio between rich and lean - this is necessary for emissions and longevity of the cat. If you map the AF mixture over time it should show a regular square wave - if you had a post-cat O2 sensor then that should flatline showing that the cat is doing what it is supposed to.
By the way, this is a trace of O2 sensors - the top one is showing a working sensor the bottom one is a dying sensor that throws an error code.
#90
#92
Steve you are a wealth of information but not every car is the same. most of our cars run super rich from the factory. i believe the +4's gunk up alot more is due to the burn flame and the explosion of the fuel is shielded by the prongs of 4 resistors and this may enhance the Rich situation. this is only a theory as like i've shown on the original Stock O2 sensor from date of purchase ran fine all the way upto the point of my header install and 3 days later confirmed with the AF Ratio sheet from the dyno run. at WOT atleast my car ran pig rich as most do. now after i find some time to put this heated O2 sensor in this week i'll let you know the results.
