96'coupe fan wiring
Old May 10, 2005 | 11:32 AM
33ron's Avatar
33ron
5th Gear
Default 96'coupe fan wiring
Hi ,I would like to know what size wire to use on the 3 Relays that are used to wire the 2 Fans,for the Radiator.Thanks Ron
1996 Vette Coupe Fan Rewiring
Old May 12, 2005 | 12:17 PM
33ron's Avatar
33ron
5th Gear
Default 96 LT1 Fan wiring
Does no one know what size wire is used on the Relays?I would assume probably #12 and #18,but you know what happens when you assume!
Someone please give me an idea,thanks Ron
Old May 12, 2005 | 12:30 PM
jfb's Avatar
jfb
#18 for the coil wiring and not smaller than #14 for the contact wiring.
Old May 15, 2005 | 12:34 PM
33ron's Avatar
33ron
5th Gear
Default 96 fan wiring
Thanks JFB
To 96'coupe fan wiring
