i was reading the service manual and it said to ground the A and B ports an the connector under the dash. both fans went on. does anyone know what would cause the fans not to go on by themselves.
thanks mike
What you did proves the fans, relays, and fusible links are working properly. It's most likely your temp switch located up front just below throttle body beside themostat housing. Drain a bit of coolant before removing it or be ready to mop some up afterwards.
Both of your fans are controlled by the ECM, since they came on when you jumpered ALDL pins A&B all is well.
The stock setting for fans is to come on over 200 deg F. (around 210-220 I think). You can change that setpoint with a custom EPROM in the CalPac or you can install a manual fan switch.
Well actually, I know you know more than me Jim but mine would work when jumping the A&B pins but my temp switch was bad so all may not be well. If the temp switch isn't telling ECM to ground the fan relays then all can be well from ECM on but not work due to the switch. You are correct in that if he's not letting temp get above 200 then all may in fact be well.
If the ECM temperature sensor were bad, the engine would run poorly. It might never go into closed loop, it would either exhibit a fast cold, idle when warm, or have no cold idle when cold.
How hot are you getting the engine in order to determine that the fans aren't working? On my car (1984) the main fan doesn't kick in until about 225* (stock).
i started the car a few days ago and left it runing in idle waiting for a lean oxigen check light to come on like usual i went in the house for maybe 30 min then come out and its smoking with a hole in the side of the coolant surge tank. also i tried grounding the cooling fan temp switch and they didnt go on.
RACE ON!!!
Well maybe so. Are you sure it's the same sensor? I know the one inbetween the #6 and #8 plug is for the temp gauge. I'm wondering if that could be the one that also affects the closed loop thing. I dunno?? I'm not at home where my helms is at but my 90 ran fine when the temp switch was out and fans wouldn't run.
I'm sure that the main fan is controlled by the ECM, and that the ECM has only one source of engine temp information. Do we even know what year this car is? I am relying on 65Z01's comment, that since both fans came in the diagnostic mode, that the ECM controlled both fans. That makes me believe it is a newer model. The cars I am most familiar with have the main fan ECM controlled and the aux fan controlled by the fan switch in one of the heads. Which head changes by specific model year. The sensor in the other head is, as you say, for the dash gauge.
The surge tank is unpressurized. The water can't stay over 212* F. It will boil instantly. Pressurized water inside the cooling system, routinely exceeds 212* F. When it got so hot, what did the gauge read?
Depending on the year of your car, I think you were grounding the dash gauge sending unit. You can have someone watch the gauge when you do it again. Most L98's have the aux fan switch on the left side. Try grounding that wire.
the one i was testing was on the right side right behind the oil dip stick.
Thats for the temp gauge. Un hook it with car cool then start it and see how your temp gauge stays at 0.
The one for the fans is up front just under the throttle body. Remove the plastic acordian from TB and you will see it. It's simular if not identicle to the one by dipstick.
It's a 90 like mine.
The ECM does control the fans but relies on the sensor to tell it to do so. Jumping A to B just simulates the sensor then the ECM grounds the fan relays switching the power the relay is holding at bay on to the fans.
so you think i need a new sensor or could it be a bad wire going to the sensor and it is the sensor in the front of the motor.
It could be the sensor, it could be the wire or the ECMs ability to read from the wire. It's just under the plastic acordian tube that connects air filter box to throttle body. Remove the band clamps that hold the acordian and remove it and look right beside the thermostat coolant inlet and you will see it.
Jumper ALDL pins A&B and start the engine.
Watch the SES flash rate for a minute or two.
Initially it should flash at about 2Hz, while the ECM is in open loop mode.
Eventually the ECM will go into closed loop mode and the flash rate will slow to 1Hz...if both the O2 sensor and the coolant temp sensor (under the TB in the intake base) are ok.
This will verify if the ECM is getting good coolant temp data from the sensor.
If you suspect the coolant temp sensor you can measure it's resistance cold and hot. It should read several hunderd k Ohms cold and a few hundered Ohms hot.
how do you watch the ses flash rate with a meter or is their a light
thaks
It's to the right of instrument cluster in that square section above the AC/heater controls. It should light up along with others for a second every time you start the car as a bulb test to let you know the warning light is working.
i jumped the A&B like you said it started blinking i left for a minute then started backing down the driveway and it stoped and stayed off. i took the wire that i grounded it with off and the service engine light came on and stayed on.
