Sway bar links
Old May 10, 2005 | 04:34 PM
Vetteboy77au's Avatar
Vetteboy77au
Default Sway bar links
Hi,
I remember reading somewhere you can get special adjustable links for the sway bar to control arm, because mine feels like it is under a lot of pressure just sitting there. Are they worth it and where do i find them?
Chris
Old May 11, 2005 | 12:28 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by Vetteboy77au
Hi, I remember reading somewhere you can get special adjustable links for the sway bar to control arm, because mine feels like it is under a lot of pressure just sitting there. Are they worth it and where do i find them? Thanks Chris
The bar should pivot easily when the links are disconnected. If not you need to check the mounts and make sure everything is in alignment. No real need for adjustable links unless the bar is bent or a non-stock bar is used.
