fuel injection cleaning
Old May 11, 2005 | 12:23 PM
mjfox's Avatar
mjfox
Default fuel injection cleaning
Any one know how to disable the fuel pump easily to perform a fuel injection cleaning
Thanks Mike
Old May 11, 2005 | 12:32 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Pull the FP fuse.
If the injectors are on an L98 it is not recommended to use harsh cleaners through the injectors as they can attack the coil windings.
Old May 11, 2005 | 12:41 PM
ZumZum's Avatar
ZumZum
Thanks Mike
Pull the fuse, then start the car and let it run until it dies. Then crank the motor just a little more to be sure you have all the pressure out of the fuel line.
Old May 11, 2005 | 06:03 PM
skybolt31's Avatar
skybolt31
Originally Posted by 65Z01
Pull the FP fuse.
Does anyone know what cleaners to avoid? I have an 86 and I have the hose and adaptor sold by Ecklers. In their catalog, they sell a 3M cleaner, #08912, I looked at the 3M web site and they have two cleaners in a can, #08956 and #08955. I am not sure what the differences between them are. Anyone try these?
Old May 12, 2005 | 12:53 AM
parafrog's Avatar
parafrog
From: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
strangely enough, i was just looking at a chevy tech bulletin last night(not sure of it's date but it was for the 85), and it said to use 95% gasoline and 5% gm top end cleaner--for what that's worth.
frog.
Old May 12, 2005 | 01:27 AM
OdinsRage's Avatar
OdinsRage
are those GM multec injectors? God, I hate those! They always crap out SO easily!
To fuel injection cleaning
