Line Lock???
Old May 11, 2005 | 01:25 PM
Dougs 90's Avatar
Dougs 90
Default Line Lock???
I have seen these on our Vette's, Who has em and how did ya do it? Pictures if you can please...
I am thinking about adding one to mine.
Thanks,
Doug
Old May 11, 2005 | 02:01 PM
STL94LT1's Avatar
STL94LT1
Just bought one, going to install it this weekend.
Old May 11, 2005 | 02:34 PM
TA's Avatar
TA
You can kinda see in this picture where mine is mounted on my 91.
Old May 14, 2005 | 01:08 AM
Dougs 90's Avatar
Dougs 90
ttt
Old May 14, 2005 | 01:21 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Here's a few, I have them on both cars, after I upload them and submit this reply, I'll try to describe what I've posted.
Old May 14, 2005 | 01:22 AM
Mr Mojo's Avatar
Mr Mojo
The pics of the solenoid located on the frame are on my '95. Kind of like a stealth install, so nobody would see it under the hood and it's something different except I believe the heat from the cat nuked it.
My brakes work just fine though.
The other pics are of my automatic, the solenoid is mounted on the master cylinder.
All plumbing and wiring is the same as the '95.
Old May 14, 2005 | 02:36 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Hey Mike... where did you get yours and how much did you shell out for it if I can inquire???
Old May 14, 2005 | 07:56 AM
rws.1's Avatar
rws.1
What is the purpose of a line lock????
Old May 14, 2005 | 08:01 AM
Mr Mojo's Avatar
Mr Mojo
As Hurst calls it, Roll Control. You plumb it into the front brake line to hold the front wheels locked while you hit the gas to do a burnout.
Some folks will use rear wheel line lock to hold on the starting line or even on a hill for daily driving(stick cars obviously).
It saves your rear brakes from overheating when doing burnouts. I've seen rotors turn bright orange and cars catch on fire because the brakes got too hot due to no line loc being used.
The first two videos are non line loc burnouts and the second two are with a line loc.
http://temp.corvetteforum.net/c4/mrm...9burnoutmq.wmv
http://temp.corvetteforum.net/c4/mrm...burnoutci3.wmv
http://temp.corvetteforum.net/c4/mrm...oburnci2-1.wmv
http://temp.corvetteforum.net/c4/mrm...ojoburnci3.wmv
Old May 14, 2005 | 09:50 AM
STL94LT1's Avatar
STL94LT1
Jegs, around $74 including the installation kit.
I'll get a pic as soon as I get it installed, or you can stop by and check it out.
Weather permitting I'll be at MM next Friday.
-Mike
Old May 17, 2005 | 11:12 PM
Dougs 90's Avatar
Dougs 90
Would you post pix of yours please?
Doug
Old May 17, 2005 | 11:21 PM
Dougs 90's Avatar
Dougs 90
Mojo,
Any tricks or pointers for the install? Anything that you would do different this time? Anyhting make it easier?
Thanks,
Doug
Old May 18, 2005 | 01:07 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Line lock burnouts are boring.
Old May 18, 2005 | 01:21 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Make sure you hook up the wires right or poof smells great,and its not rubber.
Becareful when you use it ,at times if you don't wait for the ABS noise in the rear and pump up the brakes it can lock the front tires on you .
Just bang the break peddle with your foot and mash the buttom a few times and it will unlock.
My button I ran to the shifter,just below the shift ****.
It cuts the pucker factor when at the drags,doing a burn out.
The car will sit there all day if you want .
Make sure you read the directions and snugg up the nut on the top of the unit.
I think they ship them with the nut lose,just to see if you read the directions.
To Line Lock???
