looking to buy a dist. read other posts and if i cant get the msd with out the coil in the cap then what are my options for a one piece like the factory one.
When I put my ZZ4 crate motor in my car, I also swapped the distributor for a late model V8 EFI distributor. It allowed me use higher performance external coil from MSD. The swap was pretty painless as I only had to buy the distributor connector pig tails and splice them into the original wire harness. The junk yards are full of these distributors or Summit sells new units.
thanks. where is friendswood in texas. i use to live in big spring tx. and that was a long way from kansas toto. anyhow ok let me run down the parts list . distributor, external coil and wiring adapter and oh, money.
by looking at ur avatar pic seems lkike highly modded,
Dude hypertech coil/rotor/cap, Accel 8.8 yellow wires,
MSD 6al multi spark discharge, accel distributor, ur choice of
plugs some got success with bosch or some rapid fire or
cut back or split thats upto u, I installed all these with bosch
4plus no problem, With ur setup iam sure (looking at pic)
MSD will help i felt so much diff after i installed msd it was just
amazing moment it shocked me surprised me.
