Brake Booster Replacement
Old May 12, 2005 | 08:19 PM
Black_Vette's Avatar
Black_Vette
Default Brake Booster Replacement
I have a 86 Vette that I need to change the brake booster on, I am just wondering if someone could help me out and give me any tips or tricks on how to get the old one out. Any info would be of great help.
Old May 12, 2005 | 11:57 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
I think there's a tip and trick for brake booster installs. if not, email me and i'll send you one i have... vinnie
Old May 13, 2005 | 10:23 PM
game on's Avatar
game on
Buy the GM service manual for your car.
I'm an accountant and swapped out my bad unit for a new unit in my garage using the 85 GM service manual. Lots of sweat and frustration, but "got her done".
Not easy, that's why techs $ demand in my opinion, is reasonable. If I had it do over again, buy the part and let a tech do the work.
For me, sorta like going to an Auto Zone employee, to prepare your tax return!
Old May 14, 2005 | 02:02 PM
84bronzevette's Avatar
84bronzevette
very simple job. unbolt master cylinder (leave lines on) and pull forward about5-6" . disconnect vacuum line front of booster. Go under dash and remove lower panel. pull pin and washer retaining the pushrod and lift it off of brake pedal pivot. Next is the only difficult part and is relatively easy with a ball swivel, 12" extension and 13mm socket. Remove the 2 nuts retaining the booster (either side of the brace in front of the brake pedal) Lift booster out. Reverse to install. measure the booster pushrod to master cyl mounting surface to make sure it is the same dimension as the one being replaced to avoid excessive pedal travel or brake drag. Good luck.
Scott
Old May 14, 2005 | 10:28 PM
shotchkiss's Avatar
shotchkiss
Remember to reset the cruise and stop light switches on the pedal bracket under the dash also. Easy to do, press brake in, slide the two switches forward, release brake pedal, it automatically adjusts them for you when it shoves them back. At least that how it worked on a '89
To Brake Booster Replacement
