Do I need a tranny cooler?
Old May 13, 2005 | 03:08 PM
Lichen's Avatar
Lichen
Default Do I need a tranny cooler?
I just had my '93 A4 tranny rebuilt. Heavy duty components, shift kit and 2500 stall converter. Do I need a tranny cooler or is the factory one sufficient. I plan on doing a little racing, but not much. Just concerned about the hot Arizona summers.
Old May 13, 2005 | 03:11 PM
fast.asleep's Avatar
fast.asleep
I'd grab a trans cooler. -cheap piece of mind
Old May 13, 2005 | 03:53 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Yes, and I recommend the B&M stacked style.
Also, Moreperformance sells a Ultradyne? and it is nice and thin, but looks like it will be a really great fitting cooler.
PS, my 93 with 2800rpm and 3.75's has one. No guage, but when I put my Raytek laser on it, it is usually around 170 degrees with my 24000GVW cooler.
I hope others can express there temps, especially the guys that have factory guages for transmission temps, and with high stalls etc
Old May 13, 2005 | 04:59 PM
Lichen's Avatar
Lichen
Thanks, I'll check them both out.
Old May 13, 2005 | 05:26 PM
Morley's Avatar
Morley
Most trans builders reccomend using an aux trans cooler with a 2k & up stall converter installed.
Old May 13, 2005 | 05:30 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Yep, just DO IT!
Old May 13, 2005 | 05:44 PM
Dougs 90's Avatar
Dougs 90
I would get one, the fella that rebuilt mine wouldn't warranty the transmission if I didn't let him put a heavy duty cooler in mine. Was considered part of the rebuild price....
Doug
Old May 13, 2005 | 07:28 PM
montie98's Avatar
montie98
Dont are cars use the radiator for trans cooling or is it not effecient enough?
Old May 13, 2005 | 07:45 PM
steve40th's Avatar
steve40th
The factory cooler thats in the radiator is very small. My BeCool has a pretty good sized one in there, but since heat is the trannys biggest enemy, besides my right foot, i would cooll it as many ways as I can. They are cheap, definitely compared to a transmission rebuild.
vader86's Avatar
vader86
The radiator's cooler sucks.
ANYONE with a 700r4/4L60 needs a tranny cooler, even if you dont have mods. It'll double the life of that transmission.
Old May 14, 2005 | 01:07 AM
Dougs 90's Avatar
Dougs 90
Thats what the ole redneck said about mine, that and the fact the radiator cooler was crap. He put a 2 row HD cooler in the very front. Trust me he hated pulling the shroud, but even took the time to clean out between the radiator and whateverthe ac cooler is called.
Doug
To Do I need a tranny cooler?
