VB&P Upper A Arm Poly's ?
Old May 13, 2005 | 08:26 PM
mothersworry's Avatar
mothersworry
Default VB&P Upper A Arm Poly's ?
I am installing the VB&P upper Poly bushings for the upper A-Arm. The stock setup uses a small washer on one side so the threaded bar slip through. Anyway I know I have to replace the large washers, however do I install the small washer as well?
Old May 13, 2005 | 08:53 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Use 'em all. Just like the stock setup and everthing goes back together just perfect
Old May 13, 2005 | 09:04 PM
89corvetteken's Avatar
89corvetteken
Default vb&p
I to used the VB&P upper and they say not to use the small washer of which I did not.works well,you can go to their web site for detailed instructions.
To VB&P Upper A Arm Poly's ?
