Catalytic converter question
Old May 13, 2005 | 10:54 PM
kkonen's Avatar
kkonen
Default Catalytic converter question
I am running Hooker headers on my 95 LT1 with 6-speed and corsa exhaust. I need to know which catalytic converters will fit. I had the car up on a lift today trying to figure out how to get the cats to fit without melting my floorboard or boiling my transmission. I need a cat small enough so I can put a heat shield on it.
The dynatech cats from summit are 4" diameter and 11.5" long. They appear to be the smallest cats available. Does anyone have experience with these cats? I need to pass a Texas sniff test.
Thanks.
Old May 13, 2005 | 11:00 PM
kkonen's Avatar
kkonen
I read this on the Dynatech site:
NOTE: These products are intended for racing and off-road applications.
Not legal for sale or use in the state of California, nor in states which have adoptedCalifornia emission standards.
Should I be concerned about passing a sniff test?
Old May 13, 2005 | 11:09 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
They say that about a lot of aftermarket parts because they have to. I've got a pair of 3" straight thru stainless cats that are only about 5 1/2" total width with heat shields already built on them. You should have no clearance or heat problems on a six speed if you're putting them parallel to the trans. You should have room to spare. These are new and unused. If you can use them, $150 for the pair.
Old May 15, 2005 | 03:23 PM
kkonen's Avatar
kkonen
ttt
Old May 15, 2005 | 04:08 PM
STL94LT1's Avatar
STL94LT1
I run the Dynatech PowerCats on my heads/cam/EM Headers 94 M6. It passed Missouri's emissions testing with this setup. But, I'm getting read to run a larger camshaft, who knows then.
Old May 15, 2005 | 10:00 PM
kkonen's Avatar
kkonen
Do you have any pictures of the underside of the car?
To Catalytic converter question
