4L60E Rebuild question
Old May 14, 2005 | 12:52 PM
merrick's Avatar
merrick
Default 4L60E Rebuild question
My 4L60E rebuild kit supplied a approx 1/4" cup plug. Is that to plug the LO/1st(accumulator bleed) in the trans case. There is a captured ball in this location now. For picture reference--The captured ball is illustrated but not labeled in the following link. Go to the bottom illustration "transmission case". The item is the one on the right.
http://www.artcarr.com/instructions/documents/17050.pdf
What does this do to the trans?
Old May 14, 2005 | 01:35 PM
Mr6spd's Avatar
Mr6spd
This will eliminate the hydraulic cushioning effect that the 1-2 accumulator has on the apply of the 2nd gear servo piston. In other words it makes the 1st to 2nd gear shift much harder.
Would I recommend installing it? No! It results in a very hard, harsh shift all the time (part throttle included).
There is a much better way to adjust the 1-2 shift firmness: Find some washers that have an ID that will fit over the accumulator piston shaft (pin). Vary the amount of washers to limit how much the 1-2 accumulator piston can move. You know can adjust the 1-2 shift firmness by changing the washer stack height.
Old May 20, 2005 | 05:33 AM
PBA's Avatar
PBA
The plug he is replacing is necessary for the 2nd & 3rd gear circuit, "do not" remove it! It can do "no harm" by leaving it in there.
Old May 21, 2005 | 01:17 AM
merrick's Avatar
merrick
I didn't install the supplied plug anywhere. I still don't know what it was for, I was only assuming it went in the case. I would still like to know for future reference.
To 4L60E Rebuild question
