Man I getting tired of this. I need to get the bolts from the engine to the tranny out. I have already done the ones from the flexplate to torque converter. Any hints would be great!! I don't see how you can get in there to get the bolts out.
From: [Quote=WOEII] Is dried brown doodie powders man! [/Quote]
The extensions are the way to go. When I pulled mine I removed the C-Beam and driveshaft and left the trans supported by the jack. I tilted the engine and trans down (check carefully for clearance by the firewall) and removed the top two bolts first.
Gotta tilt the engine/trans as far as clearance will allow. Then using a 3-4 foot extension and universal socket (6 point) and a 1/2" drive ratchet, proceed to bust some knuckles and let your neighbors know every 4 letter word in your vocabulary.
