U Joint question half shafts
Old May 15, 2005 | 12:42 PM
John G 92's Avatar
John G 92
Default U Joint question half shafts
I installed the Spicer 5-800X U Joints in my half shafts. The problem is not the movement of the caps pressed into the half shaft that is fine but when installing the U Joint into the Yoke end going to the wheel hub bearing it was a very tight fit and to pry to get the caps to get in the to holders in the Yoke and after tightening down the two yoke straps it has a lot more tension on the movement not binding though it's smooth but seems to hard to move compared to moving it the other way. Any ideas? I know none of the needle bearings are out of place.
Old May 15, 2005 | 04:28 PM
John G 92's Avatar
John G 92
I figured it out the Yoke had a little left over metal from maybe the casting or maybe the old u joint got it out with the dremel and it's fitting perfect now. case closed
