Proform Roller Rockers
Old May 15, 2005 | 09:14 PM
65coop's Avatar
65coop
St. Jude Donor '05
Default Proform Roller Rockers
What Roller Rockers seem to be the best?
I'm looking at a set of Proform's for the center bolt valve covers at around $200.00 - Any feedback?
Old May 15, 2005 | 09:24 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Complete junk, stay away from them. I saw a set fall apart in just a few thousand miles. Good ones are Comp Cam Pro Magnums, Crane Golds, etc. Don't scrimp here.
Old May 15, 2005 | 10:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Pony up another $100 and get a set of Comp Cams ProMagnum RRs along with hardened guide plates and push rods.
Old May 15, 2005 | 10:51 PM
65coop's Avatar
65coop
St. Jude Donor '05
Is this what I'm looking for? Roller Rockers
Who has them in stock and do you know what the part numbers are?
Old May 15, 2005 | 11:26 PM
65Z01's Avatar
65Z01
Summit sells them or you can go directly to Comp Cams.
I found that the latter move got me parts next day when Summit was out of stock.
What year Vette & what engine are the RRs going into?
Old May 15, 2005 | 11:32 PM
65coop's Avatar
65coop
St. Jude Donor '05
1990 L98 w/ stock heads and aftermarket valve covers (center bolt)
Old May 15, 2005 | 11:41 PM
rodj's Avatar
rodj
"Is this what I'm looking for?"
It is if you have a motor with self aligning rockers , generally the roller cam motors,post '87.
Different part no for earlier motors.
Other eBay vendors have Pro Magnums as low as $260.00
Old May 16, 2005 | 12:48 AM
65coop's Avatar
65coop
St. Jude Donor '05
The car is a '90 with the L98 motor - Does the '90 have self aligning rockers?
Old May 16, 2005 | 12:57 AM
65Z01's Avatar
65Z01
Yes the L98s from '88 through '91 with the #113 Al heads had self aligning rockers.
Indeed you can get the non self aligning ProMagnums for around $260. I think that hardened push rods and guide plates will run <$100.
If you plan to rev your L98 into the region where you can really use 1.6:1 RRs you should install better valve springs and new keepers. Also, toss the tin oil shedders that are atop your stock springs to lighten up the valve train a little.
Since you have aftermarket valve covers I can't say if you will need to do any machining on them to clear the RRs.
Old May 16, 2005 | 06:10 AM
93 ragtop's Avatar
93 ragtop
I got the crane golds because they came with a hotcam kit I purchased. If I was going to buy a set again, I would go with the pro mags. I put a set of those in a friends chevelle and they are nice pieces.
To Proform Roller Rockers
