Engine Accessory Interchange
Old May 16, 2005 | 01:28 AM
warriorvette's Avatar
warriorvette
Default Engine Accessory Interchange
What are the accessory mounting differences between an 89 L98 and an 89 iron head 5.7L that came in P/U's? Will a supercharger bracket taken off an iron head 89 P/U fit the L98?
I am just not sharp enough on Chevy small blocks. New convert from MOPARs (if I am allowed to say that in this room ).
Thanks.
Alan
Old May 16, 2005 | 03:01 AM
rodj's Avatar
rodj
The bolt holes appear to be standardized across all the later SB motors so if an item bolted to one it should bolt to another.Even aftermarket heads have the same positions.
The belts / pulleys may not line up as different setups use for different applications
