92 OEM exhaust experiment
Old May 16, 2005 | 09:38 AM
Strick's Avatar
Strick
Default 92 OEM exhaust experiment
I have an OEM catback with muffler elims on it and the OEM resonator. I have a X-pipe and want to know where the best place is to install it. Options: 1) replace the resonator with the X-pipe. 2) Keep the resonator and install the X-pipe in the same place that the LT4 exhaust have a crossover pipe.
Which option would produce the least amount of resonance and which would be best for performance? Opinions?
Thanks guys
Old May 16, 2005 | 03:13 PM
Strick's Avatar
Strick
No comments?
Old May 16, 2005 | 04:04 PM
Toy90's Avatar
Toy90
If it helps any, I have a 94 with aftermarket cats, H pipe in place of the stock resonator and stock mufflers. I recently put on elims and the sound was insanely loud, sounded terrible, and I lost low end. Last weekend I cut out the H-pipe and put a stock resonator back in. It sounds great now and I'm glad it turned out so good. I don't have any resonance at all and the sound is sweet to my ears. I don't know if your cats are stock but this is something to consider. That resonator has a large affect on the sound and volume even though you can see through it.
Old May 16, 2005 | 06:37 PM
Strick's Avatar
Strick
Thanks for your comments. I'm leaning towards trying an X-pipe where the LT4 exhaust has a cross over pipe in the rear just before the pipes make a turn to the mufflers. So, I'll have shortie headers, oem cats, oem resonator, an X-pipe and then the elims. I'll let you know how it sounds and performs. Meanwhile, I'll keep my B&Bs on for daily driving and shows. You're right, too much time on my hands.
Old May 16, 2005 | 06:51 PM
sraft's Avatar
sraft
I'm playing around with a very similar setup. Right now I've got the mufflers cut off and am running with the with the cut up stock exhaust. It's boomy and resonates inside the cabin too much , but I suspect with the elims installed the pipes will extend out to the bumper and it should sound better. If that doesn't work, I have a set of stainless flow through mufflers (I got them used and don't know who they're made by) that I'll try. When I get it sounding good I'll post my experiences.
Old May 16, 2005 | 07:16 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Tom, the only way to know for sure is to install it and takes it's temperature. They'll be one area that is significantly hotter than anywhere else. That will be the place to put it. I can get a digital "point and shoot" thermometer anytime I need it. That's how I did mine. Let me know and I'll get it.
Old May 16, 2005 | 08:30 PM
LT4BUD's Avatar
LT4BUD
Thanks guys
Since you don't have mufflers I would say put the x-pipe in front of the resonator, if you can make it fit. This should produce the least amount of resonance, also balance out the exhaust better than after the resonator
I have a prototype x-pipe coming in 3" that will fit between my hi-flow cats and the B&B resonator.....so the right x-pipe would fit up there..
If you want to go extreme, then add an H-pipe where the factory LT4 h-pipe is located.
Just replacing the resonator with the x-pipe would probably be the best performance option, but also probably the loudest. In addition to flow consideration the x-pipe probably weighs 20 pounds less than the resonator...
Just my thoughts..
Old May 16, 2005 | 08:32 PM
LT4BUD's Avatar
LT4BUD
Meanwhile, I'll keep my B&Bs on for daily driving and shows. .
Old May 17, 2005 | 04:12 PM
Strick's Avatar
Strick
Originally Posted by LT4BUD
Just so you know, I have a B&B exhaust that is pretty quiet and I was playing around with my OEM exhaust. It'd be fun to have a loud note when heading for the track (auto-X). Maybe I can scare those Miatas off the track. My B&B is a very nice upgrade from OEM. Now my wife's Durango R/T isn't louder than my Vette!
To 92 OEM exhaust experiment
