clutch
Old May 16, 2005 | 06:09 PM
1996man's Avatar
1996man
Default clutch
what is the going price for a lightweightflywheel clutch combo? for the ZF in my 96
Old May 16, 2005 | 06:58 PM
Zix's Avatar
Zix
How heavy duty do you want to go? The best options I have seen are;
Centerforce Dual Friction
McLeod Twin Disc
SPEC Stage 3+
with an aluminum flywheel they all range in the $950-1150 range. If your looking for a clutch for close to stock HP range then it won't be quite as much!
Old May 16, 2005 | 07:34 PM
cresus's Avatar
cresus
Just so you know I have a Fidanza aluminum flywheel I'm selling (brand new) for $315 + shipping. This will make your total cost much less.
Old May 16, 2005 | 10:14 PM
1996man's Avatar
1996man
i wish i could.
Old May 17, 2005 | 07:32 AM
cresus's Avatar
cresus
You can also go with a stock replacement clutch kit that'll only cost about $300 also. I bought a Luk clutch which seems really nice. If you use a single mass flywheel you have to get a sprung hub clutch which means you can't use the stock disc. Instead, some people use the clutch from a camaro or firebird and the corvette pressure plate. This is the most economical solution as it sounds like you're trying to get away for the least amount of money.
Old May 17, 2005 | 09:58 AM
1996man's Avatar
1996man
i just got a reply back from carolina clutch and the price was a lot better than i anticipated so i think thats what im gonna go with
To clutch
