LT1 Mod Questions
Old May 17, 2005 | 03:00 PM
CAJUN C4's Avatar
CAJUN C4
Default LT1 Mod Questions
C4 Tech. FAQ and need help with some of the Recommended mods that do work.
1) What's a removable Frisbee ?
2) Where to find info on the Electric Water pump? Can it be used on the street?
3) Beem Plates? (must be suspension related)
Thanx
Old May 17, 2005 | 03:29 PM
Lone Ranger's Avatar
Lone Ranger
1. Frisbee is an L98 thing
2. Meziere makes one, and several forum guys are running them on the street
3. I dunno either
Old May 17, 2005 | 11:15 PM
Hotred94's Avatar
Hotred94
Beam plates are essentially oversized washers that provide increased clamping power to hold the C-beam onto the differential and transmission.
Old May 18, 2005 | 01:29 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Water pump can be run on the street but I would run a light inside the car incase the pump quits you can see the light go off.
C- beam plates are to expensive for what they are.
Not on your LT1 engine for the other ?.
Old May 18, 2005 | 03:35 AM
thanke's Avatar
thanke
Do you guys have temp gauges? I'm wondering why the light inside?
Old May 18, 2005 | 06:41 AM
REDC4CORVETTE
If the pump gets a short or loses power you know right away.
I know the pump only last for some of us about 2 or 3 years.
Yes you can look at your temp gauge a few miles down the road and wait 10 hours for an LT1 to cool down.I want to know before I pull out of the drive way ,to save that walk back to the house.
Old May 18, 2005 | 11:04 AM
vader86's Avatar
vader86
The frisbee is on 88-91 vettes, not LT1s.
You should get the Meziere, its the best of those out there, it doesnt last as many years as the stock one will but it will cool the engine better. Any overheating problems you have now will probably go away.
Old May 18, 2005 | 11:10 AM
CAJUN C4's Avatar
CAJUN C4
I assume a Miziere is an Electric LT1 Water Pump. Where can I get one?
and how much HP do you think it free's up??
Old May 18, 2005 | 09:36 PM
gslotman's Avatar
gslotman
according to F-body websites (and dyno run B4 and after) this pump is worth approx 9 rwhp and 8 rwtq - throughout ( ) entire rpm range
95 6spd
Old May 18, 2005 | 09:57 PM
thanke's Avatar
thanke
95 6spd
If you are looking for hp gains. You might want to check some other options? I'm not sure what mods you have, but exhaust might be a good start? Cat back/headers and such? Maybe ported throttlebody, cam and heads?
Old May 18, 2005 | 10:22 PM
vader86's Avatar
vader86
I'd get one from Summit, it usually gives back about 10ish hp.
I wouldnt do it for the power gains though, do it if you need the better cooling or need a new WP already.
Old May 19, 2005 | 09:33 AM
CAJUN C4's Avatar
CAJUN C4
I',m Planing on buying a friend of mine 95' next month. I currently own an 84' but 11 years is star wars leaps ahead in technology.I'm planning my Mods as this is a bone stock LT1.Only seen routine maintenance.Let me know what Mods you think
I should do.Need an extra 50 Horses or so.
Old May 19, 2005 | 09:59 AM
Nathan Plemons's Avatar
Nathan Plemons
Info on LT1 mods that do / don't work
http://www.wku.edu/~nathan.plemons/h...rformance.html
To LT1 Mod Questions
