after 18 years my vacume lines ar shot and I have done a horse s*it job of keeping them working. where can I get some replacement one and also do you have to use the hard plastic lines or can you use some rubber ones if so where to find them... Thanks
You can get both rubber and hard lines at any part store.
DO NOT replace hard plastic lines with rubber, hard plastic is used for a reason, usually because of heat. And get the right size, do not buy all one size. You can cause problems by not running the right size hose, if it is to small you restrict the air to much and the same with to big.
