Hard to get into gear
Old May 18, 2005 | 06:46 PM
shottel's Avatar
shottel
Default Hard to get into gear
have a 95 that has not seen alot of abuse. It is getting harder and harder to get into first and shift to other gears. Does this sound like slave cylinder is going? How do you diagnose?
Old May 18, 2005 | 07:01 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
No it does not sound like the slave. It does sound like it is time to change the trans fluid. If it's never been done before it is long overdue.
Old May 18, 2005 | 09:24 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Sounds like you're low on clutch fluid.
Old May 18, 2005 | 10:40 PM
shottel's Avatar
shottel
trans fluid changed last year and slave cylinder is full of brake fluid...
Old May 24, 2005 | 07:04 PM
shottel's Avatar
shottel
how does one know that a slave cylinder is bad (other than the obvious leakage)?
Old May 24, 2005 | 11:49 PM
cv67's Avatar
cv67
St. Jude Donor '05
Wondering if the leakage could be internal , ie fluid leaking past the plunger.
Old May 25, 2005 | 08:47 AM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Jack the car up and get under it. Remove the two nuts that hold the slave cyl in the bellhousing, remove slave cylinder. Look at the front where it rubber boot is, if there is any fluid AT ALL, it's leaking. Replace it.
BTW, you can do all of the above without removing any hoses.
To Hard to get into gear
