1990 idling
Old May 19, 2005 | 04:09 PM
1990C4 ConvertUK's Avatar
1990C4 ConvertUK
Default 1990 idling
1990 L98 doesn't like to idle cleanly when warm. Doesn't cut out but rev's drop to almost cut out and hunts a bit, any ideas? Idles ok when cool.
Old May 19, 2005 | 04:45 PM
JAKE's Avatar
JAKE
If it idles okay when cold but not when hot, that points to a closed loop problem.
There are a few things that should be checked; using a ScanTool or Diacom will make pin-pointing the cause much easier. It's probably one of the sensors operating out of range.
02, TPS and coolant temp sensor are prime suspects.
Try checking to see if there is any error code stored.
Jake
Old May 19, 2005 | 05:33 PM
pipe's Avatar
pipe
I'm kinda havin the same problem with my 90 I have a post on a later page. One guy told me to OHM my injectors after it was warmed up. You might give that a try. They should ohm at least 15 ohms give or take an ohm or two. If they ohm alot lower then you might have a bad injector. My car seems to surge after it's warmed up when coming to a stop. And it shouldn't be a fuel filter problem. HOPE YA GET IT STRAIGHTENED OUT.
Old May 19, 2005 | 06:25 PM
1MoorTym's Avatar
1MoorTym
Does that happen only when the fans kick in ?
My car idles perfectly at 800rpm until the fans run and then the extra load drops the idle to a choppy 6-700rpms.
Old May 20, 2005 | 06:54 PM
pipe's Avatar
pipe
My chip was redone and my fans kick on right away. It doesn't have a problem till it warms up. When my injectors went bad a few yrs. back the hotter it got the worse it ran. It wanted to stall and cut out while running down the highway at speed also. I just finished OHMing the injectors and all were fine. I think I have a vacum leak somewhere.
Old May 20, 2005 | 08:04 PM
Ivory90's Avatar
Ivory90
Do a search in this section on IAC, your IAC may be carboned up...it's been written about extensively.
Cheers.
Old May 20, 2005 | 09:51 PM
cv67's Avatar
cv67
St. Jude Donor '05
My 89 did the same exact thing when I bought it. EGR, 02 sensor and injectors
Get a proper diagnosis though, before throwing parts at it.
To 1990 idling
