engine replacement
Old May 19, 2005 | 05:25 PM
88espo's Avatar
88espo
Default engine replacement
Well I must have kicked a rod and need suggestions on a replacement bullet any help? I have an 88 and looking for a little more than stock, but not to break the piggy bank!
Old May 19, 2005 | 05:39 PM
FoolCrzy's Avatar
FoolCrzy
the GM crate ZZ4 is an easy swap. you could put 1.6 rockers on it for a little more hp.
Old May 19, 2005 | 05:41 PM
88espo's Avatar
88espo
Who has the best price on them?
Old May 19, 2005 | 05:42 PM
FoolCrzy's Avatar
FoolCrzy
not sure, really. i think Scoggins Dickey may have them. I know jeg's sells them, and Summit might. It's pretty much a late L98 with a little bigger cam.
Old May 19, 2005 | 05:44 PM
GeosFun's Avatar
GeosFun
The biggest restriction in this year (and all TPI's) is the intake manifold and runners. That is why so many forum members go with Superram or aftermarket large tube runners/intake manifold. The basic engine is pretty good. So you need to really consider your induction options as much as the short block.
Since you are going to replace the short block anyway, a ZZ-4 with enhanced induction should probably give you an easy 50+hp over stock (bigger cam, more compression, otherwise about the same as the
L-98), plus another 35hp from induction.
That puts you at about $2,000 on the ZZ-4, GM-short block and another $1,000 give or take on the induction (still using your throttle body). I don't think the short block has a cam, so that is an add-on too. Still pricey but I don't see anything much less than that worth having. If you pass on the induction, you will probably be dissappointed in anything you put together.
A number of aftermarket builders have 383 short blocks for about the same price. You might just consider taking a deep breath and taking the plunge. Try Golens Engines website and also Speed-o-motive's website. Those will give you a good perspective in what's out there for quality and competitive prices.
Old May 19, 2005 | 05:47 PM
FoolCrzy's Avatar
FoolCrzy
http://www.jegs.com/cgi-bin/ncommerc...29&prmenbr=361
$3799.99
88espo's Avatar
88espo
I ported the plenum on the motor that was in there and made a big difference, I went almost 103 in good air. I will put the accel intake on for sure.
Old May 19, 2005 | 05:52 PM
88espo's Avatar
88espo
I left a call to a friend who is a chevy service manager and will see what I can get it for from him. I hope much better than that or I will just buy the short block and put the good cam in and spend a few bucks on the heads.
Old May 19, 2005 | 07:23 PM
Togo's Avatar
Togo
i know you said you didn't want to break the piggy bank, but i figured i better post this anyways!
http://forums.corvetteforum.com/show...77&forum_id=55
To engine replacement
