Could a bad o2 sensor....
Old May 19, 2005 | 10:59 PM
MrNuke's Avatar
MrNuke
Default Could a bad o2 sensor....
Cause the car to be running rich all the time?
I just took the car out for the first time this year, started right u, runs fine, but seems a bit on the rich side, my A/F gauge is pegged at 100% rich al the time. Not sure if the gage is bad, or the O2 is mezzed up.
My FuelPressure Gauge shows the FP changing from normal to WOT, so that seems to be working good.
Thanks in advance.
Old May 19, 2005 | 11:06 PM
JAKE's Avatar
JAKE
The one time I had a bad 02 I got a lean mixture error code. So I guess it depends on the voltage reading the 02 was sending when it died.
A bad 02 won't set any code, but you should get a lean or rich error code if your 85 system is the same as my 86.
You can try jumping the A&B terminals of the ALDL to see if the system is going closed loop. One flash per second indicates closed loop and faster flashes indicates open loop (if memory serves).
Jake
Old May 19, 2005 | 11:10 PM
MrNuke's Avatar
MrNuke
Cool.. I'll try that this weekend.. thanks..
Old May 20, 2005 | 01:38 AM
JCAIRE2's Avatar
JCAIRE2
Jake
Just to correct, that is backwards. The SES light will flash slowly in open loop. When the car goes closed loop and feedback from the O2 is used by the ECM, the SES light will flash with the transitions from lean to rich. A properly working O2 with constantly transition from rich to lean and back again.
Old May 20, 2005 | 09:24 AM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
I just bought a new o2 sensor at advance auto parts, $20 and it was a Bosch. Pretty cheap if you think its the problem.
Old May 20, 2005 | 09:32 AM
LD85's Avatar
LD85
Put a volt meter on your O2 signal wire and see if your mV's re jumping
Old May 20, 2005 | 09:42 AM
Corvette0096's Avatar
Corvette0096
Gabe long time no see. They are like $22 for our year of car for the bosch..
Old May 20, 2005 | 10:47 AM
vader86's Avatar
vader86
Bad O2 is almost always the culprit, and almost never sets the O2 code.
Old May 20, 2005 | 10:58 AM
MrNuke's Avatar
MrNuke
Yeah I had the O2 replaced 3 years ago,and I have a heated Bosch O2 I haven't installed yet since getting the headers, so I'll probably put that on. Ill mess with it this weekend.
Old May 20, 2005 | 03:57 PM
JAKE's Avatar
JAKE
Isn't that what I said??
In closed loop the SES light will flash at a rate of 1 time per second and in open loop it will flash faster, which, according to the Shop Manual, will be at two and one-half times per second.
Here's the quote: "If the Diagnostic terminal is grounded with the engine running, the system will enter the Field Service mode. In this mode, the SERVICE ENGINE SOON" light will show whether the system is in Open or Closed Loop.
In Open Loop the "SERVICE ENGINE SOON" light flashes two and one-half times per second.
In "Closed Loop", the light flashes once per second: . . ."
Jake
Old May 20, 2005 | 05:04 PM
JCAIRE2's Avatar
JCAIRE2
Oopps, sorry Jake, looks like I had it backwards, lol.
Old May 20, 2005 | 05:14 PM
JAKE's Avatar
JAKE
LOL, No problem. At least someone's reading the stuff I write.
Jake
Old May 21, 2005 | 08:48 AM
Atok's Avatar
Atok
Man, you guys are making me dizzy.
Now the way I read these posts you guys are agreeing on opposite things. JAKE, I think you're backwards, JCAIRE2 is correct.
Open Loop - O2 Sensors too cool to work, ECM ignoring them - SLOW flash...1 per second.
Closed Loop - O2 being used by ECM - Fast inconsistent flash, light on for RICH O2 reading.
Old May 21, 2005 | 09:40 AM
MrNuke's Avatar
MrNuke
Ok everyone make up your minds..
Old May 21, 2005 | 06:36 PM
JAKE's Avatar
JAKE
If you noticed, I posted the direct quote from the Shop Manual.
OPEN = FAST
CLOSED = SLOW
OPEN = Two and one half times per second which means FAST
CLOSED = One time per second which means SLOW
Now, this info is from the 86 Shop Manual, but if different years flash differently, well, I can't be held responsible for that.
Any questions? LOL
Jake
To Could a bad o2 sensor....
