Early '86 head CC question
Old May 20, 2005 | 06:14 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Early '86 head CC question
Are the cast iron L98 heads 58 or 64 CC chambers?
Old May 20, 2005 | 07:23 PM
flyersfan1088
Anyone?
Buehler?
Old May 20, 2005 | 07:39 PM
scorp508's Avatar
scorp508
The aluminums were 58, so they must be 64 (or was it 72?)
Old May 20, 2005 | 08:07 PM
MrNuke's Avatar
MrNuke
If they are iron, they were 72-74cc chambers.
Old May 20, 2005 | 10:30 PM
vader86's Avatar
vader86
They are 76cc combustion chambers.
Old May 21, 2005 | 03:41 AM
flyersfan1088
So they dropped 18cc's when it went to aluminum?!?! That seems a little hard to believe. I'm not saying that it's not right, just hard to believe.
Old May 21, 2005 | 04:00 AM
Morley's Avatar
Morley
Do you know the casting numbers?
Old May 21, 2005 | 12:47 PM
flyersfan1088
No, I don't. Too much crap in the way to see the #'s. The old pistons had a slight dish. Even with the current flat-tops, a 76cc chamber would still have compression just under 9 to 1.
Old May 21, 2005 | 12:49 PM
flyersfan1088
The book Cor-Vette Specs lists 4.6 cubic inches. How many cc's is that?
Old May 21, 2005 | 12:56 PM
vader86's Avatar
vader86
They are 76cc heads, and I believe the '128s were only a little smaller than that, then the '113s dropped to 58cc.
If memory serves the last 3 digits of our casting is '624.
Run a search, it will come up if you look.
Old May 21, 2005 | 02:28 PM
MrNuke's Avatar
MrNuke
426624 was mine. POS with 76cc chambers. All over the web people say between 72-76cc on the '85 L98 TPI, which was because they were 'Smog Heads'..
Old May 21, 2005 | 02:44 PM
cmashark's Avatar
cmashark
what would be the best replacement head to bump compression and still use 87 octane?
Old May 21, 2005 | 02:46 PM
MrNuke's Avatar
MrNuke
Why would you even consider runing 87 octane??
Old May 21, 2005 | 04:07 PM
flyersfan1088
Well that certainly sheds new light. In the Summit catalog they say that a 64cc chamber with my flat-top pistons yields a 9.7 CR. I must be running high 8's with these smog heads. I guess it's time to start shopping for new heads.
To Early '86 head CC question
