Gas Gauge Problem
Old May 20, 2005 | 09:56 PM
jssc4's Avatar
jssc4
7th Gear
Default Gas Gauge Problem
Just started to have problems with my 93, the gas gauge reads full to 3/4 full and I know that I put over 200 miles on it since last fill up, and ideas what wrong.
thanks.
jss
Old May 20, 2005 | 11:18 PM
Jloshotz's Avatar
Jloshotz
My first guess would be your sender or sender plate connections are the culprit....Easy fix either way
Old May 20, 2005 | 11:27 PM
Saisling's Avatar
Saisling
St. Jude Donor '05
I believe theres a relay of some sort in the dash as well as the sending unit itself (in the tank) that control this.
My guess would be sending unit. The wires in teh tank tend to corrode over time which often messes it up.
The sending unit is pretty expensive actually. Do yourself a favor and DON'T think about taking it in to a shop. Do it yourself. This is one of teh easiest things to get to on a C4. If you have any mechanical ability, you can do it and save lots of $$$$
Check out this tech tip on repairing the sending unit...
https://www.corvetteforum.com/techti...=277&TopicID=2
I just replaced mine, and, like the tip said, it was around $300 for the part.
NAPA also sells a wiring kit (which they usually push with the new pump for around $8.00 which will have an assortment of wire and connectors if you need it for the repair.
Old May 21, 2005 | 08:52 AM
jssc4's Avatar
jssc4
7th Gear
thanks for the info , I know I always can depend on you guys.
jss
To Gas Gauge Problem
