'96 Antenna went limp
Old May 21, 2005 | 01:03 PM
borderchris's Avatar
borderchris
Default '96 Antenna went limp
Hey everybody. The antenna stayed in the up position today, and is not cooperating. The rest of the Bose CD system is fine. Any ideas or quick fixes? is it OK to push the antenna down by hand? It tees me off, because the '95 and '96 are supposed to have the fail-proof motor.
Chris
Old May 21, 2005 | 01:16 PM
DougSilver's Avatar
DougSilver
Hopefully, all you need is a mast replacement. I recently had the same problem with my 95 and picked up a replacement mast from Ebay for about $10. Problem solved.
Old May 21, 2005 | 04:33 PM
froggy47's Avatar
froggy47
You can push down CAREFULLY so you don't bend it. Fail Proof
Old May 21, 2005 | 06:15 PM
Morley's Avatar
Morley
I wouldn't go pushing it down. What has probably happened is that the plastic drive "wire" for the antenna has broken and pushing it back down will jam the drive wire in somewhere it doesn't belong...if you don't bend the antenna.
Old May 21, 2005 | 07:42 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Search the TechTips in C4 section. There's a repair remedy there. You'll have to buy a replacement mast from your local Chevy dealer. Around $35 to $40 bucks if memory serves...
Old May 21, 2005 | 09:34 PM
Aquaman92's Avatar
Aquaman92
If you can hear the antenna motor running them the mast kit will most likely fix your problem .I found the kit at Ecklers for my 92 for 29.00
Old May 22, 2005 | 07:51 AM
Casethecorvetteman's Avatar
Casethecorvetteman
my mate tried to push an antenna down on his 84 once, now it makes a nice swept back look.
To '96 Antenna went limp
