Well first of all I would like to thank the folks that helped me out.I have everything on for the carb conversion and I am so excited.The last thing I need some help is with the computer and harness.What do I keep and what do I get rid of? What needs to be hooked up to keep my dash alive?Does anyone have any pics of there wiring I could look at?
Thanks in advance
CHRISTOPHER
I really do appreciate all of you guys help.I am so ready to drive this thing after 4 years and 5 stangs
I'll be darned. I thought I was the only one doing this. I'll be doing the wiring for my '86 in the next week or so. Converting to a carb/ 383. Leave the computer in... most sensors should still work. There are probably existing jobs out there but if none show, I'll post mine when I do them. Good luck!
My progress so far:
Christopher, did you rebuild the from the block up?
yes sir I have rebuilt the bottom end.I really like your choice of carbs.I have a speed demon 750 w/mech. secondaries sitting on top of a weind x-cellerator(sp?).The motor is a 355 10.25:1,comp xe274,1.6rr's,cleaned up heads.I would like to find a better set of heads though.My engine by no means looks like yours though.I had to pick my jaw up off the floor.That is just BEAutiful.
