From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Lose the wing, the front end, the scoop, and the wheels, and it's a nice looking vette.
I have a question...
With boost, is it really that helpful to have the scoop forward?
Would a rearward cowl induction work 99% as good? Even with a cowl, the base of the windshield is a high pressure area, just less so. It doesn't seem like a blower would really need the ram air, after considering how much drag and windnoise that scoop would cause.
Originally Posted by bogus
I always thought that the area near the cowl was low pressure?
In nascar, and on the vette, the top of the windshield is actually a low pressure zone. I think on brickshaped cars, it's the other way around.
(at 180 mph anyways)
With boost, is it really that helpful to have the scoop forward? It doesn't seem like a blower would really need the ram air, after considering how much drag and windnoise that scoop would cause.
The scoop isn't for getting air to the blower, it's for getting air to the intercooler, so it can cool the air charge, savy?
Okie, I'm a dummy Tim, yeah point it forward.
Those FEAs (finite element analysis) aren't mine. Too bad he didn't put mirrors on the car, or put the ground in there. I'm actually doing some heat transfer FEA at work right now though... Really cool stuff.
- Mount the intercooler directly on top of the superram. (Think WRX Sti hood scoop/intercooler setup)
How will the air exit the intercooler if it is sitting on top of the superram plenum? You would need a huge cowl for this as well.
Some other things I would like to point out. Picking up air above the exhuast manifolds/headers is not the greatest idea.
Having the blower mounted on the drivers side, and running pipe to the passenger side, then back to the throttle body seems like a piping mess as it has to cross over itself maybe a bit more then 1/2 the way.
Why not go front mount intercooler?
Or turn the super ram plenum into an Air to water intercooler, like the votech mondo coolers design for the 5.0's?
with the throttle body mount on the drivers side, you could get the piping from the blower to the throttle body real short. intercooling takes place after the throttle body.
of course you have the whole water resivour and cooler to deal with.
