Throttle cable too short??
Old May 23, 2005 | 09:07 AM
ztrips's Avatar
ztrips
Default Throttle cable too short??
I installed a BBK throttle body, but after I hook up the throttle cable it looks like it holds the butterflies open just a crack. I thought they were supposed to stay closed and the IAC controlled air at idle. If you look at the side of the TB there is about 1/4 to 3/8 inch gap where the stop screw is contacts the "arm" on the side of the TB.
Confused....
Edit: I think I found it.. Crazy search. DIdn't pull this up the first time, but sounds like my answer..
http://forums.corvetteforum.com/show...throttle+cable
