Newbie question re closed/open loops
Old May 23, 2005 | 09:28 AM
rstackjd's Avatar
rstackjd
Default Newbie question re closed/open loops
'88 auto
one of the diagonistic flow charts in the Helms manual says to
"Start engine and run until system goes "closed loop"
How do I know when it goes "closed loop"?
Old May 23, 2005 | 01:18 PM
JAKE's Avatar
JAKE
You can insert a bent paper clip or wire as a jumper into the the top, two right hand opening in the Assenbly Line Diagnostic Link (ALDL). These are the A&B terminals. The ALDL is located under the dash, right near where your right knee would be with you sitting in the driver's seat.
The Service Engine Soon light will begin to flash. It will flash at two and one half times per second to indicate OPEN LOOP and ONE TIME PER SECOND to indicate CLOSED LOOP.
Jake
Old May 23, 2005 | 01:37 PM
Morley's Avatar
Morley
Or, hook it to a scanner or laptop running free scanning software. Either will tell you when you are in open or closed loop.
Old May 23, 2005 | 02:40 PM
rstackjd's Avatar
rstackjd
ok thanks - thats helpful.
Old May 23, 2005 | 03:28 PM
VenkmanP's Avatar
VenkmanP
The usual way is to just let it warm up to operating temperature.
Which doesn't guarantee that its in closed loop, but that's really what the manual is telling you to do.
Old May 23, 2005 | 03:32 PM
rstackjd's Avatar
rstackjd
A ha - thats the answer I was looking for - easy! Thanks, even I can understand that much.
Old May 23, 2005 | 04:39 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
When is closed loop begun? Does the ecm look for a reading from the 02 sensor to see if it's heated up? Or is it based on coolant temp, or???
...or when my idle goes from rock solid to crappy?
Old May 23, 2005 | 04:48 PM
JAKE's Avatar
JAKE
In open loop the ECM uses coolant temp and TPS to control fuel and timing.
Once in closed loop, the ECM primarily uses 02 feed back, but also MAF, TPS, coolant temp info.
Before the system will go closed loop, several conditions must be met, like 02 voltage cross counts, count-down timer expired, minimum coolant temperature and maybe some other things I can't recall right now. There's a listing in the Shop Manual, but I don't have it in front of my now.
Jake
Old May 23, 2005 | 04:49 PM
CentralCoaster
Cool, I'll check my helm manual.
To Newbie question re closed/open loops
